Question about Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Black
Like rider fx wheels won't move
Plastic sleeve pipe falls out of wheel and then wheels won't turn.
    Problem Solver:
We just bought one of these for our son as well. Put it together, charged it and it simply wouldn't work. After having my father in law who is basically an Electric technician take a look at it, he found loose connections, most notably on the little part that you plug the charger into (the charging diode). After re-soldering a major loose connection found on this part, it completed the circuit for the bike and it started to work.
Best thing to do in this case is that you check all connections in the body of the bike (you can turn it over and take out all the screws on the bottom to get to the major board under the main power and direction switches). But for us the main problem was where the charger plugs in.
Like most Chinese products, these were put together way too quickly and not checked for quality before being put into a box. However, after a little TLC from someone who knows about electric stuff, it is now a great fun toy for our little boy :-)
Posted on Dec 25, 2014
How can we keep the rear wheel from coming off of the drive shaft?
Lil' Rider Black 80-Kb901K Fx Wheel Repair Questions ...
www.fixya.com/.../p13170224-lil_rider_black_80_kb901k_fx_wheel_b...
Recent Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Blackquestions, ... How can we keep the rear wheel from coming off of the drive shaft?
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike Instructional Video .... Why does the right wheel keep sliding off the tire gear, leaving it free-wheeling? ... WORST piece of trash I've ever triedto assemble! congrats groupon, you ... axle through, this will keep the axle and motor and drive gear fitting tight.
Jan 08, 2016 | Lil' Rider Black 80-Kb901K Fx Wheel...
The bike will go in reverse but won't go forward. how do I fix this?
Lil' Rider FX 3 Wheel Battery Powered Bike, Black - Amazon ...
www.amazon.com/Lil-Rider-Wheel-Battery-Powered/...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Black: Toys & Games. ...On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... VTechGo! ... sound effects, working chrome colored headlight, and forward and reverse ...power wheels vehicle more to handle size, weight, and your child won't ...
Lil' Rider FX 3 Wheel Battery Powered Bike, Blue - Amazon ...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Blue: Toys & Games. ...Sold by: Global Supplies (We currently can't ship to, HI, AK,APO,FPO, POB) .... Ride On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... sound effects, working chrome colored headlight, and forward and reverse ...
? 8:05
Jan 07, 2016 | Lil' Rider FX 3-wheel Battery Powered Bike...
What is Lil riders phone number
? 8:05
Step by step instructions for quick and easy assembly of your KB901 Lil' Rider FX 3 Wheel Battery Powered ...
Lil' Rider Repair Questions, Solutions and Tips... - Fixya
www.fixya.com > Forum
Dec 14, 2015 | Lil' Rider Black 80-Kb901K Fx Wheel...
Lil rider 80 kb901
with the rapid of developing, more and more plastic generated. how can we do with these so many wastes. tires, plastic rubber??? http:www.doinggroup.com/
Dec 25, 2013 | Cars & Trucks
What causes ztr front wheel to squeek in motion?
i would take them off and clean off the old grease and apply fresh grease on all moving parts including the the wheel caster section
Jul 14, 2012 | Toro Zero Turn Rider 74366 Lawn Mower...
Steering wheel changes
Here is the simple steps to change the old steering wheel and install the new one.
Remove the Original Steering Wheel
1.Read instructions that come with the steering wheel, and gather the following tools: screwdriver, pliers and a puller.
2.Point wheels straight ahead.
3.Disconnect battery or pull horn fuse before removing the old wheel. This prevents the horn from shorting out or blowing during installation.
4.Remove the horn mechanism by doing one or more of the following steps: Press down on the horn cap or ring and turn; remove the emblem cap from its snapped-in position by grabbing it and pulling it toward you or prying it loose; or if the horn ring is secured by screws that are concealed in the rear side of the wheel spokes, use a screwdriver to remove the screws and the ring.
5.Remove horn wire or spring-loaded metal plunger from plastic housing by either pulling straight out on the metal plunger or, on most models, by twisting the plastic sleeve to the left and then pulling out. Cut the wire off the plastic sleeve and keep the sleeve for later use.
6.Remove the shaft-nut retainer clip, if it is present, and keep for later use. Remove the shaft nut, which holds the wheel to the shaft.
7.Mark the shaft at the twelve o'clock position so that you will know where to position the top of the new wheel.
8.Insert a conventional puller into the two tapped holes which appear in the hub of the old wheel and pull off the steering shaft.
9.Remove the original wheel.
Installing the New Steering Wheel
1.Place the small tubular metal sleeve down over the steering shaft.
2.Position hub on splined shaft, making certain that the shaft is properly positioned using the mark you made in step 7. You may have to rotate the plastic horn contact tube slightly to align it with the appropriate hole through the hub.
3.Insert plastic sleeve and spring from step 5 without wire into plastic horn housing. If the plastic sleeve extends above the top bolt surface of the custom hub, cut down the sleeve so that it is 1/8-inch below the top of the hub. Remove sleeve.
4.Insert through the plastic sleeve the wire lead that was supplied in the wheel kit. One end will not pass through the sleeve. This bell-shaped end will go into the horn contact housing. Insert the sleeve and wire into the housing and lock into position.
5.Route wire around the hub from the ten o'clock position to about the two o'clock position to properly align wheel. Position post cover and wheel on hub. Make certain that the wire lead passes through the appropriate holes in the two o'clock position. Using the three shoulder bolts provided, fasten the hub, post cover and wheel together, but do not tighten.
6.Check wheel for proper positioning. If correct, reinstall the shaft nut from step 6 and tighten. Reinstall shaft-nut retainer clip. If the retainer does not fit into the groove on the shaft, tighten the nut until it will fit as originally located.
7.Remove shoulder bolts and reinstall them through the retainer ring with the fiber side toward you. Tighten the shoulder bolts with caution - excess torque will result in damage to the hub. The shaft nut, if correctly tightened, will firmly hold the hub and wheel assembly on the shaft.
8.Connect wire lead to the connector on the retainer ring. Position spring on center nut. Align the dimples of the horn cap with reliefs in fiber material and push into the dimples past the fiber. Turn cap left or right until tight.
9.Reconnect battery or replace fuse.
Sep 09, 2010 | 1991 Honda Accord
Goes in to four wheel drive but front tires are
Look at the back of the front wheels there is 2 black pipes, 1 for the brakes that conect to the brake unit (callipers) and the other one is the vacume pipe. Most of the time it is damaged. This pipe is softer and thinner than the brake pipe. It will have a inner pipe and outer sleeve (pipe) that is loose from the main pipe, just to prtect the inner pipe. It can have a leak under that sleeve. ENJOY from Willem Potchefstroom SA
Feb 27, 2010 | 1998 Kia Sportage
Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Black Logo
478 people viewed this question
Top Lil' Rider Cycling Experts
ray gallant
Michael Smalls
Michael Smalls
Level 1 Expert
Are you a Lil' Rider Cycling Expert? Answer questions, earn points and help others
