Question about Zoppini Farfus - White Dial & Stingray Band Chronograph
How to remove links from a kim rogers watch? - Zoppini Farfus - White Dial & Stingray Band Chronograph
Kim Rogers Accutime Watch BK7R21
Send the watch back to Belk as it may have more problems than just a battery.
Jan 07, 2014 | Watches
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    Won't tick
    instruction manual for radio watch sm2452 required
    Jun 20, 2010 | Dakota Watch Company Travel Alarm with...
    Lost back on gold vicence watch where can I buy one Kim
    The most likely source of of a spare is to contact the maker.
    Youcan find their contact details on http://www.vicence.it/vicence-watches.html.
    Apr 02, 2010 | Vicence Woven Strap Watch
    My boyfriend purchased a Nautica Watch model N22528 after the holidays and the box had no instructions how to use the Tachymeter. how can I go about getting some information for him so he'll stop driving...
    If you cannot go to a local dealer then the information is available on their web site. They require the watch to be registered before releasing the instructions. To do this:-
    Go to the web site "www.nauticawatches.com"
    Select "watch info"
    Select "warranty & manual"
    You now need to register the watch.
    Jan 07, 2010 | Watches
    I have a Breitling aerospace and the date is wrong. How do I set the date? Roger
    Here is the link for Breitling Aerospace:
    http://vbr.com/doku/breitling4.htm
    I hope this will be helpfull.
    Do not forget to rate, please.
    Jan 13, 2009 | Watches
    Zoppini Farfus - White Dial & Stingray Band Chronograph Logo
    Top Zoppini Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Zoppini Watch Expert? Answer questions, earn points and help others
