Question about Camera Mohawk Mtr-2110 Tripod
Mohawk tripod MTR-2120 dips
Tripod does not keep camera level, in that the camera with a heavy lens dips forward.
My camera is falling forward off tripod when I let go of it after a few seconds. I've tightened all the knobs and I need to fix this today..
Without knowing the make and model of the tripod and the type of the camera, I can only be general/
The camera may be too heavy for the tripod head. Heads are rated to hold so much weight. If the camera/lens combo is too heavy for the head. it will tip forward. Many department store grade tripods can handle only light cameras.
The locking mechanism may be damaged/broken.
If you need more info, please repost the question, specifying the make and model of the tripod and the type of the camera. If it takes interchangeable lenses, also include the make and model of the lens.
Dec 27, 2016 | Photography
Can you use the Davis & Sanford FM18 tripod head with a Canon Rebel camera and 150-500mm lens?
You should be able to, there is nothing about the camera or lens that is incompatibl with that tripod. Just make sure the tripod has all its parts.
Apr 24, 2014 | Sanford Davis & ProVista Airlift Tripod...
How do you use the 100-400 CANON LENS tripod ring mount
Once mounted on the tripod you can loosen the ring to swivel the camera (and lens) from landscape to portrait position.
Feb 09, 2014 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
How much weight will the Velbon Victory 250 Tripod hold
The tripod will certainly hold your Canon camera and lens. However the limiting factor is the head. Without knowing the head you have mounted on the tripod I'm afraid I can't tell you whether it would hold your camera and lens.
Jul 30, 2012 | Velbon Victory 250 Tripod With Quick...
Tripod mount for canon 75-300 mm lens
The XTi (400D) needs to be attached firmly to a tripod with a tilting head to enable you to counteract this.
Jun 26, 2012 | Canon EF 75-300mm f/4-5.6 IS USM Lens
Rokinon 800mm F/8 Multi-coated Lens for Nikon will this go on a nikon 5000 Thanks for your time
Yes. Of course, the lens isn't an autofocus lens so you'll have to focus manually. Also, the lens does not have the electronics to communicate with the camera, so you'll have to shoot in the manual exposure mode without any assistance from the camera's exposure meter. You can review photos and use the histogram to fine-tune the exposure.
You're probably going to want to use a tripod to hold the camera steady. The lens is long enough, magnifying even the slightest camera movement, and heavy enough that it's almost impossible to hand hold.
Jul 14, 2011 | Rokinon 800mm f80 Lens
Sunpak 5800d tripod quick release plate. What is the correct position to mount it on the camera and the tripod? Also what is the push button on the plate and how is it used? Thank you
Go to this site and look at the plate mounted onto the tripod, do it that way, so the bubble level is on your side, and the second little push button opposite of you. The second button is there for larger cameras, many video cameras mostly, that have two holes on the bottom, to keep them from swiveling side to side on the plate. Also, makes it easy to ensure you put it on right in the dark, the extra button should go toward the lens. :o)
Apr 12, 2011 | Sunpak 5800D Tripod
I just bought a battery grip for my canon camera. but the grip ceases when i am using it for work. please help find solution
Is this battery grip a Canon or aftermarket accessory? Have you mounted the camera to a tripod if so what lens do you have on the camera? Are you using the adapter for the use of AA's or are you using the LP-E8 battery pack? Are you using the camera in portrait position or landscape?
Here is why Canon has had in the past some problems with battery grips but I thought it was a solved issue maybe not on the entry level DSLR's. What happens is there is enough flex between the body and the grip to break connection and yes it seizes up. Most Rebels will have a plastic lens mounting flange which will also flex with the weight of a lens (longer focal lengths). Also with the longer focal length lens it has more a tendency to flex the battery grip if mounted on a tripod. Holding in the portrait position the weight of the camera is actually pulling away from the contacts so there is a whole series of little possibilities. If it's a Canon accessory then it's a warranty thing if it's aftermarket Humm not sure should have something on it but, the quick fix is to keep tightening the mounting screw/wheel. I know that wasn't the fix you wanted but hey just telling the way it is.
Jan 17, 2011 | Canon Battery Grip (BG-E8) for Canon EOS...
Canon 10D works fine after impact but overexposes now.
HI I AM SAGHA A CAMERA REPAIRER FROM MUMBAI,YOU SAID YOUR CAMERA WAS FALLEN ON THE FACE WITH LENS THEN STARTS OVR EXPOSING PICTURES THEN FIRST CHECK YOUR LENS'S APERTURE IS WORKING FINE OR NOT.ATTACH ANOTHER LENS TO YOUR CAMERA & THEN CHECK THE EXPOSURE THEN IT WILL BE CLEAR WHETHER YOUR CAMERA IS DEFECTIVE OR LENS IS DAMAGED INTERNALLY.REPLY ME ABOUT IT.THANK YOU & ALL THE BEST
Aug 02, 2009 | Canon PowerShot SD1000 Digital Camera
Canon 400D with EF 100-400 Zoom lens
I wouldnt chance it but get a good heavy one with metal locks and such
Dec 26, 2007 | Velbon Sherpa DV7000 Tripod
Camera Mohawk Mtr-2110 Tripod Logo
80 people viewed this question
Top Camera Photography Experts
Tony
Are you a Camera Photography Expert? Answer questions, earn points and help others
