Question about Mitsubishi CS-32309 32" TV
Picture curves in from sides a little, and top horizontil line comes down 1/3 way and peoples faces are lost. all we have is chin and hairline. after an hour the screen pops back and no problem for the evening.
  • shans12215 May 19, 2009
    What are convergence module mits? This tv weights just this side of a ton and tv shop says they don't do home repair???
    I am wondering if tube is bad. the set is over 10 years old.
    thanks
    Steve
  • 126 Answers
This set may have convergence module mits are good for alot of these problems take to tv shop they will help ya okay its probally 100.00 fix okay good luck
Posted on May 18, 2009
Hi can anyone please advise me how to repair a hairline crack in a astracast composite black kitchen sink, the crack is a just above the curve on the facing wall of the sink just before the base.
You may try clear super glue into the crack on both sides, bowl side and under side of bowl). Make sure to remove excess immediately, for bowl side.
Jun 13, 2015 | Astracast Home
No heat
hi take heater cover off back of dryer on top you have 2 stats take left 1 off turn upside down if it looks bent inward that is faulty try this. side which faces heater element give it a good nock on hard surface if it curves out it should work now but sum stats you cant do this u can bypass stat just to try it but only try dont use dryer with stat bypassed its dangerous if you have to buy stats they come in pairs one with spot and 1 wthout its one with spot usually 1 gone but put both in if you buy sum
Feb 06, 2014 | Dryers
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
The little fan disc came off the top spleened motor shaft. Does it make a difference which side is facing down when I put it back on?
As long as the blades of the fan are flat (not curved) it doesn't matter. I'd be more concerned that the fan will probably come off again. Unless it's one that's held on by a screw it's just a push-fit and, having come loose once, it will never be a tight fit again. Good luck anyway!
Jan 23, 2010 | Vacuums
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Curved picture
ur problems is on the pincushion check for a capacitor that its bad on the pincusion section  good luck.
Nov 01, 2007 | Televison & Video
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
