Question about Explorer Appliances RC Crash Dive Submarine
Crash dive submarine won't go up and down. Can it be fixed?
My Yahoo Messenger hangs then it would say (not responding...). What can i do to fix this? Help me please?
Few sugesstions :
1) Check whether if your windows is installing new updates, sometimes YM does crash when window is updating. If you are using Win7, then just go to:
--> Control panel/ System & security/ Windows Update/ Change setting. In the setting panel, you will see " Important Updates " box selection. Change it to "Check for updates but let me choose whether to download & install them". Restart your pc/laptop, then try log in to your YM.
2) *This step won't be necessary but won't do any harm too, go to:
Control Panel --> System & Security --> System --> Advance System Settings. In the " Advance " tab, click "setting" at the " performance " column. Select " Data Execution Prevention ", select " Turn on DEP for all programs & services except those i select", Insert your YahooMessenger.exe (C:/Program Files/Yahoo!/Messenger/YahooMessenger) into the add list. Restart PC/laptop & try to log in to YM.
3) If those won't work, uninstall your current YM, restart your pc/laptop, then try installing a new one. Link : a)http://www.mydigitallife.info/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/ b) http://www.geckoandfly.com/6309/download-yahoo-messenger-10-full-offline-installer-15-8mb/
** If it still crash, then your internet connection might be the problem, & also, Yahoo! can be down sometimes too.
Jun 08, 2011 | Yahoo Messenger
Which way does the bezel turn on a tag watch
Tag Heuer watches are constructed with scuba-diving bezels-- that is to say, it only turns COUNTERCLOCKWISE. This is so that when you are diving, you set the triangle marker to the time you went down. If you accidentally bump your watch while diving, it will move only counterclockwise, leading you to think you have LESS time left to dive, which is so much safer than thinking you have MORE time to dive, than you really do.
May 03, 2011 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
I have an Oceanic Veo 100 Dive computer, and It has been working very good It has never fall down or recieved any damage, but the first time I changed the battery, It show the error BAT, and it does not...
Generally dive computer batteries are NOT a do it yourself job and need an authorised dealer to undertake. It is imperative that the correct battery is used and that the watch is pressure tested for leaks and calibration. I recommend you send your computer to an authorised scuba service centre. Sorry, hope that helps.
Sep 07, 2010 | Oceanic "Veo 100" Dive Computer Triple...
I have a rolex submariner and it occaisonally vibrates. What is the problem with this.
Sounds like mainspring is not holding in place and getting undone (unrolls by itself), that what usually causes the vibration.
W-Precision
Mar 19, 2010 | Rolex Daytona 116520 Wrist Watch
I need spare part for my k3 submarine watch: I need Screw Down Case Pipe + Crown. Where can I find it in Australia?
Assuming that these parts are unique to your make of watch, then according to their web site there are no distributors in Austrailia.
If you go to their web site (www.vostok-europe.com/), you will see a map of the world and the countries that have distributors are shown in red.
Your nearest distributor is in Indonisia but you could just a easily order one from an English speaking country (to increase the chances of getting what you want!)
Feb 02, 2010 | Vostok Europe "K3 Submarine" Black Dial...
Jumper setting
you can keep master either hard disk or rom not both. there must be one slave and one master for one ide slot
Jun 12, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
Submariner Winding Slips
crowbar040, you may have a problem with your mainspring click, which is supposed to keep the spring coiled as it winds. What might be happening is it is sticking and coming undone instead of winding. Or you could have a bad gear in your automatic.
Apr 28, 2008 | Rolex Daytona 116520 Wrist Watch
Explorer Appliances RC Crash Dive Submarine Logo
16 people viewed this question
Top Explorer Appliances Toys Experts
ray gallant
Are you an Explorer Appliances Toy Expert? Answer questions, earn points and help others
