Question about Nintendo 64 Console
N64 works but the Picture has loads of static
I plug the N64 into the wall, that's fine, I then plug the thin cable into the back of the tv and turn it on and the picture has loads of static, its barely playable. Do I need another lead connecting to an aerial or something please respond ASAP.
  • 30 Answers
It sounds like it's most likely a problem with the AV cord you're using to connect to the TV or the ports on the TV where you plug it in. If you can, borrow a friend's AV cable and see if it works, if not then it's either a technical problem elsewhere or it is not hooked up correctly... Also make sure the TV is set to the correct input (Video 1, Video 2, channel 3, etc.)
Posted on Oct 22, 2007
Hi I can't figure out how to get my N64 to work on my samsung flatscreen. My friend showed how to do it a while back but now i've forgotten. I've been told I need a scart cable but I...
Whoever told you you need a scart cable is wrong, The N64 is an old console therefore requires you to plug it in via a standard ariel port. You then should turn you N64 on and search for new channels using your TV menus to either automatically search for them or you can tune your tv manually. either way you will probably need to fine tune afterwards. If you need more help please e-mail me at garleet@hotmail.co.uk
Aug 11, 2011 | Nintendo Video Game Consoles & Games
How do you connect your nintendo 64 to your tv
You need two cables. One has a very large, thick end that fits into the back of the N64. That is the power cord, you just plug that one into the wall. The other cord is a little trickier. It has a smaller end that plugs into the back of the N64 to the side of the power plug. On the other end of that cord, you have composite cables. (The red, white, and yellow plugs). Just find the matching color plugs on the back of your TV, set it to the correct input, and you're all set! I hope this helps!
Apr 11, 2011 | Nintendo Video Game Consoles & Games
Iv had an n64 before so i think i have a good idea of how to set it up. i've managed to tune my tv in to find where abouts it is but there's only a black screen.i can turn the n64 off an the tv screen goes...
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position. While the control deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the control deck.
Move your control deck farther away from your TV. If the control deck is too close to the TV, the control deck may cause some interference.
Jan 19, 2011 | Nintendo 64 Console
My n64 turns on and is hooked up to the tv and it doesn't show any picture or has any sound coming out of it
make sure your connection on the back of the N64 is all the way in the N64. Also check the connections on the back of the TV to make sure you have them plugged into an "input".
Dec 08, 2010 | Nintendo 64 Console
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Snes screen jumps on certain tv
Okay, what I would try is hooking up the snes using the n64 cable. right next to the rf slot in the back of the super nintendo is a slot thats the same video output as the n64 you can plug in the rca cables from it and see if they work
Feb 27, 2009 | Nintendo Super NES Console
Sony KP-43t75 - Front panel buttons and IR sensor stopped working
TRY UNPLUGGING THE SET FROM THE WALL FOR 2 MINUTES THIS WILL ACTIVATE THE AUTO RESET WHEN YOU PLUG THE SET BACK IN.
Dec 28, 2008 | Sony KP-57WS500 57" Rear Projection...
N64 will not play on new TV and Stereo Reciever
I bypassed the stereo reciever and plugged the cords into imput 2 in our tv. It works fine.
Nov 29, 2008 | Nintendo 64 Console
Sabre 42 in plasma tv stuck on component 1
remove the power from the wall and leave the TV off for at least an hour, the static charge may have shorted the circuit board for the pront panel controlls.
after an hour or so plug it back in to see if has reset itself
hope this helps
regards
Nov 27, 2008 | Televison & Video
Nintendo 64 Console Logo
318 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
