Question about Mitsubishi WD-73838 73" HDTV-Ready DLP TV
Hi! Mitsubishi WD-73838-heard a loud pop and screen went black. is it the lamp? Thanks!
Mitsubishi WD-73838 -no picture. TV was on, heard a loud "pop!" And the screen went black. Power stayed on and still had sound but no picture.
ctf1800
  • 4402 Answers
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Posted on Dec 08, 2007
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
phil_frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
SOURCE: HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
Posted on Feb 11, 2010
  • 418 Answers
SOURCE: TV MADE A LOUD POP NOISE AND THEN WENT BLACK
Pop could be lamp.
Posted on Apr 19, 2010
I have a Mitsubishi 65inch tv, Model WD-60735. I heard a loud pop noise, like if something burst inside. Then the screen went black but I can still hear sound. Shortly after the sound went out. I can hear...
Check your lamp. This is a common problem in projections. Sometimes there is a lamp door and two screws holding it in. you can physically see if it is bad. itll be shattered or have rings aorund it. anything that doesnt look right. If your lamp is fine then you may have blown a fuse or diode or ic chip..theres really a lot to go wrong. I would then take it to a repair shop.
Please take the time to rate. Thanks:]
Apr 22, 2011 | Televison & Video
I turned the TV on and heard a pop. I now have a black screen. Nothing works. The Timer light is green when on but not the power light
Hi:
This is an indiccation that your lamp has failed, replace the lamp and you will be good to go, If you heard a pop this was the lamp shattering in its enclosure. Just replace you lamp.
Feb 27, 2011 | Mitsubishi WD-60735 Projection Television
I heard a loud pop and my TV went black this morning, can you tell me what the problem might be?
It sounds like your TV lamp popped this lamps are rated for 6000-8000 life hours witch is a average time of 2-4 years take the lamp out I'm sure you will see broken glass inside the lamp I found the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=WD-73735
Sep 07, 2010 | Mitsubishi WD-73735 Television
Heard a big popping sound then the screen went black and the red light when on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jul 02, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
T.v. clicking and wont turn on..
Hello:
The loud pop you heard is usually indicative of a failed lamp. The clicking noise you hear is likely the ballast trying to turn the lamp on.
If you need assistance with a new lamp, please feel free to contact us at www.dlplampsource.com or 866-764-5822.
Regards
Dan
Apr 12, 2009 | Mitsubishi WD-65731 65" HDTV
Jan 30, 2009 | Mitsubishi WD-57734 57" HDTV
Mitsubishi WD-73838 73" HDTV-Ready DLP TV Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
