Question about Maytag Atlantis MDE6400AY Electric Dryer
Maytag electric dryer model mde9606aya will not start when button is pushed. there is power to the dryer
  • 355 Answers
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the houseCheck to see whether there's power getting to the dryer. Is it pluggedin? If you plug something else into the outlet, does it work? If not,check for a blown fuse or tripped circuit breaker.
Door switchIf the door switch or the door-switch actuator is defective, the dryerwon't work and you need to replace the failed component. The switch isinside the dryer main housing near the door frame. Sometimes you needto raise or open the top or front of the dryer to reach the switch.
Thermal fuseOn many dryers, there's a thermal fuse (a heat-sensitive fuse thatblows if the dryer overheats) mounted to the exhaust duct inside theback cover panel. The fuse is about an inch long. It's usually embeddedin black resin and mounted in a white plastic housing.
Ifthe fuse has blown, it has no continuity. When this happens, your dryereither just stops heating, or it doesn't work at all. Be sure toinspect the venting/heating system before replacing the fuse to put thedryer back into operation. (You can't re-set this type of fuse.)
WiringOften the main wiring connection from the house, at the dryer, burnsand the connection breaks. In this has happened to your dryer, you needto replace the power cord and the terminal block inside the dryer towhich the wire is attached.
Posted on May 17, 2009
  • 1 more comment
  • Rohit  Asthana
    Rohit Asthana May 17, 2009
    belt around the drum is broken. The light you see is the glow of the
    heating element. No air flow will cause heater to get red hot. Danger!
  • Rohit  Asthana
    or check our previous solution here
    http://www.fixya.com/support/t131832-may...
  • Rohit  Asthana
    or check the test below.....
    Check the breakers, then the wiring from the receptacle, the plug and
    then the wiring to the back of the dryer. If not there, then take the
    top off and look for the thermal fuse. Bypass it and see if it comes
    on. If so, replace it and you should be on your way.
Is there a reset button on a Maytag electric dryer purchased in 2000? Power is coming into the dryer, pushing the start button has no effect.
check the switch itself ,, you can do this with a meter and checking for continuity when the button is depressed, also check the door safety switch,, it won't run if this switch is defective,, you can check this one the same way , or just locate the connection, and add a jumper wire, to see if the machine starts
Aug 10, 2011 | Maytag Dryers
Error message appearing "power failure occurred
Push the Start/Stop button on the Neptune to reset the machine.
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Electric dryer model no w10088770 won't turn on. For a while when you hit the start button it took some jiggling for it to work. Do I need to replace to push to start switch?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Maytag HYE3658AY Electric Dryer
My maytag neptune dryer has the start button flashing but when push it nothing happens. I unplugged it and it is stil flashing when plug back in.
Did you have any power surges latley? Sounds like the control board is faulty. I think this model has a control board in the top counsel. Hopefully this helps
Jul 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer #mde9606aya quiet + heavy duty dryer won't start. There is
check your thermal fuse when it goes bad either the heat element or the entire dryer won't work.
Mar 01, 2009 | Maytag Dryers
MDE5500AYW MAYTAG DRYER WON'T START
pf means power failure. your dryer uses an extra boost of power on start-up and your is failing to get this boost you need a repair person in your area
Feb 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mde9206ayw
HI WHEN YOU PUSHED THE BUTTON TO START DID IT HUMM IF IT DID YOUR MOTOR IS THE PROBLEM ESPECIALLY THE BURNING SMELL
May 24, 2008 | Maytag PYE2300AY Electric Dryer
Flashing "touchup" and dryer won't start
This unit should be on warranty, call back the seller for service.
Nov 08, 2007 | Maytag MED9600S Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
123 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
