Question about Technics SL-MC70 60-Disc CD Changer
Discs will nor play and the message "error" is displayed. Unit will open
Unit will not load and play disc. When the play button is pressed, the unit hums and then displays the message "error". The front door is not locked and opens easily to display discs inside.
2 Suggested Answers
SOURCE: Unit is locked
Take the 4 screws from the sides and the two in the top back of the unit. What has probably happened is that you have a cd laying on the bottom of the unit and the arm can not make the entire sweep. cdt
Posted on Oct 08, 2007
The DVD player built into the unit has suddenly stopped working. We can load and eject as normal, but it doesn't play the disc. Pressing PLAY displays the "No disk loaded" message.
Disc do not loads into it properly. Is a loading mechanism fault. Contact any service technician. The disc loading mechanism should take out from the set for repair. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 03, 2015 | Televison & Video
My samsung home cinema ht-tz212 wont play discs, just says loading, then open or disc error??? ive tried cleaning fluid lense cleaner with no luck ???
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Jan 31, 2010 | Samsung Audio Players & Recorders
6 discs in system, won't play or eject
take it manually by opening the unit
Jan 20, 2010 | JVC KD-G110 CD Player
Stereo and cd player are seperate units
I take it you have a cd stacker
PRESS AND HOLD eject button,insert credit card under cartridge
Push card firmly in,move left -right,this will locate micro switch.
Cartridge should pop out so you can check discs
Dec 20, 2009 | 2002 Cadillac Escalade
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
Technics SL-MC70 60-Disc CD Changer Logo
78 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
