Question about Canon MV30i Mini DV Digital Camcorder
Requests the cassette to be removed, when trying to play or record the cassette
Whatever I want to do (play or record) the MV30 tells me to "remove the cassette" but the door will not open. I am running with battery fully loaded and the cable plugged in as well.
cpt100
  • 154 Answers
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Posted on Mar 17, 2007
SOURCE: Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
Posted on May 29, 2007
  • 6 Answers
SOURCE: cassette loading - keeps on ejecting cassette
The "remove cassette" problem on Canon DV cameras is a general fault error that can be induced by many varied problems from faulty dew sensors to jammed mechanisms. These mechanisms are small and delicate and it does not take much to stop them working. If the head drum is starting the next thing that should happen is the capstan spins which in turn drives the take-up spools when the cassette loads. Tape tension problems (other than a broken tape) would not be detected until after the capstan is running. With the battery removed and the cassette door open, CAREFULLY attempt to rotate the capstan spindle. I use a small rubber insulating sleeve stretched over a small screwdriver. If this does not solve the problem then other possibilities are that the printed ribbon cable from the cassette mechanism to the camera needs re-seating or perhaps the capstan drive motor is faulty. However, try and look for the obvious first. To investigate further by dismantling is extremely difficult and I would not recommend it unless you want to risk writing-off your camera completely. I have done this operation (successfully) as a last resort and found that re-seating the printed cable in its socket solved the problem, however, I would not recommend or suggest this decision be entered into lightly. Its a good feeling when you get it working again but sickening when you have to allocate it to the re-cycle bin. As I say, this fault indication has many causes. Getting it serviced by Canon is not an option as the cost would exceed its value so unless you can find a local repairer that's prepared to look at it, then you have very few options.
Posted on Dec 18, 2007
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
SOURCE: Canon ZR900 cassette won't eject
I also found that I couldn't operate the camera in play mode. There is a section of the troubleshooting guide that says that the "The cassette compartment cover will not open or it stops halfway while you insert or remove a tape." According to the guide the solution is one of the following:
- Battery pack is exhausted. Replace or charge the battery pack (pg 17).
- Attach the battery pack correctly.
- Use the compact power adapter.
I removed the battery pack and unplugged the power adapter, then plugged in the power adapter/re-installed the battery pack and could get the camera to operate in play mode, but when I tried to eject the cassette the camera it would not only "not" eject the casstte but it also stopped operating in play mode. I'm going to try letting the battery charge to see if that helps.
Posted on Jan 04, 2009
How can I get an instruction manual?
Recording from tape is very similar to recording from the turntable, but you have to select tape as the source. There will be a button labelled something like PHONO/TAPE/AUX with which you select TAPE and then record as you would for a vinyl disc but you press play on the tape instead of playing a record. Here's something very similar which should help you. Good luck and I hope you get to save your memories.
http://www.teac.com/content/downloads/products/755/lp-r550usb_om_efs_va.pdf
May 12, 2014 | ANDERS NICHOLSON USB Turntable With CD...
Phillips Pocket Memo 381 The button you press in when recording will not press in! Any ideas tThe machine plays back tapes OK
You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
Aug 16, 2011 | Philips Pocket Memo 381 Handheld Cassette...
Tape keeps rejecting
Have a look at the recording lugs on the left and right hand side at the rear of the cassette tape case. Check that they are still there and not loose. If you have removed them at sometime to stop it being over-recorded then maybe whatever you use - sellotape, electrical tape, duct tape, has come loose or gone soft. If none of the latter then there must be a problem with that cassette if it is the only one doing that. If it's not the only one then the problem is inside the VCR and will need to be taken to a reputable repair shop or they may do house calls.
Good Luck
Sep 13, 2009 | Televison & Video
I hava a dual cassette deck where I work, Dont know what model, but I am trying to record an existing cassette to another and cant figure it out, can you instruct me?
you have a record side and a play side make sure you have the right cassettes in the right decks, you press play on the one deck and record on the other, unless there is a sync button that starts recording. if this doesn't work tell me the model cassette and I will have another answer for you
Jan 21, 2009 | Audio Players & Recorders
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Recording stopped working
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
Apr 26, 2008 | Canon ZR200 Mini DV Digital Camcorder
Dvd player/video cassette recorder
Assuming your dvd player supports your dvd+r format. You might need to make your dvd player multi-region or remove the region setting all together.
this website have unlock codes for dvd players
http://www.dvdexploder.com/
Those cheap made in china $35 dvd players have no region setting and will play virtually anything.
Feb 23, 2008 | Televison & Video
Will not dub another tape
This site is useless. It tells you nothing.
Why does it exist?????
Jan 19, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Camcorder ZR80 saying remove cassette, won't record or play.
when you put cassette try to see the take up left side weather it rotating?if no try to rotate with your finger.may be there is a bend on that.
Nov 25, 2007 | Canon ZR80 Mini DV Digital Camcorder
Canon MV30i Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
