Question about Fujitsu Computers & Internet
Fujitsu not coming back after sleep mode - Fujitsu Computers & Internet
How to fix fujitsu t732 when it won't power on after sleep mode?
take the battery out and unplug it. Wait a minute and put it back, then try
Jul 04, 2014 | Fujitsu LifeBook T732 XBUY-T732-W7D-002...
No signal going sleep
try hibernate instead of sleep mode.
Jan 19, 2014 | Fujitsu Siemens Computers & Internet
Turn off sleep timer doesn't allow time presets
Ahrin, have you tried going back to where you purchased it? You don't need to take the unit, just go back to the store and have someone demonstrate how to operate it, they may even write the instructions for you if you don't have the owner's manual
Nov 07, 2013 | Fujitsu Heating & Cooling
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Jul 11, 2010 | Fujitsu 24C1 Air Conditioner
Slow to start after being in sleep mode
Your hard drive is spinning down and is slow to respond. Some of the old Fujitsu drives were known to do this. I would check your power saving settings in display properties and adjust it so the drive is not powering down.
Apr 26, 2010 | Apple 24" iMac Desktop
Laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
Dec 11, 2009 | Computers & Internet
Monitor goes into sleep mode and won't come back
go through control panel to Power Options, switch off the options to sleep/hibernate.
Oct 27, 2009 | Computers & Internet
It wont come on just getting a flashing light on the left hand corner.
It is possible that it is having trouble recovering from sleep mode. Try holding the power button for about 10 seconds to see if it shuts off completely. If it does not, disconnect the wall power and remove the battery. Put the battery back in and start it up.
You will probably get a notice that it was not shut down properly the last time depending on the operating system, but you should be able to ignore that error.
Sep 09, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
My cooling fan is not working
It really is like the sleep mode / Hibernate mode when it is it really his job, also for when people are sleeping out which job as sleep, the computer does so well the reason is also removing his job when sleeping in, would have understood and helped them. good luck
Jan 11, 2009 | Dell Inspiron 1525 Laptop Jet Black
Computers & Internet Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
