Question about Garden
I was mowing lawn and stopped to remove debris from lawn.I put tractor in nuetral,when I got back on it would not go forward or reverse.With the free wheel lever engaged or disengaged I can push tractor freely.
    Sniper:
  • 57 Answers
Check the drive belt.
Posted on May 18, 2009
My murray riding lawn mower stops moving in forward and very slow in reverse after about 20 minutes of mowing.
the balts are probably wore out. if they look cracked or thin in spots replace them both at the same time. should be back to new.
Jul 09, 2016 | Murray Garden
Have a John Deere lawn tractor. It starts and runs fine in forward gears, but when put in reverse it stalls . Any ideas what it may be? Could there be a faulty limit switch of some sort?
does it stall when mowing in reverse?
its supposed to do that
look for an over ride switch or button some the key has to be in reverse position to mow
check owers manual
Sep 24, 2013 | Garden
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
227 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
