Question about Car Audio & Video
No power my car stereo - sony- looses all power at 60mph + nothing works. when i slow under 40 for at least 5 minutes, it comes back on. Car toys was clueless.
Hi, help please. I have an MTX 40004 amp when i put the out put signal wires into my sub amp I get a pop (static sound) this happens every time I change the radio station or press any button on the radio or make any operation action on my radio even turning the ignition key off. This only happens when the signal wires is plug into the sub amp.
thanks a lot if you can help me much appreciated.
Posted on Oct 18, 2008
  • 631 Answers
It sounds like your charging system may be causing the problem. The voltage may be too high or the stereo may be too sensitive to high voltage. You need to connect a voltmeter to your system to make sure it's not charging over 14.5v. A normal charging system wii charge at 13.5-13.8v.
Have someone connect a digital multimeter to the B+ and ground wires of the head unit. Have a passenger monitor the voltage while driving. If the head unit cuts out at the same voltage each time and the voltage isn't excessive, the head unit needs to be repaired. If the voltage goes up above ~14.5v, the charging system needs to be checked.
Posted on Oct 17, 2007
How to recycle cmputer after reseting CEL
1.let car sit overnight. 2. Start engine, put A/C on high, let it idle for 20-25 minutes, 2, then drive car uninterrupted for 60mph for 10 minutes, 3. slow down to 25 mph for 4 minutes, come to a complete stop with foot on brake let it idle for 2 minutes, 4. drive again at 30 mph for 8 minutes, come to a complete stop let it idle with foot on brake for 3 minutes. 4. Drive at 40 mph (turn off overdrive) for 6 minutes. 5. Drive at 20mph for 3 minutes at a time, each time coming to a complete stop with foot on brake for 2 minutes. Do this 4 times. Let the car cool overnight and repeat entire process. Then check status of systems with a code scanner.
Apr 15, 2014 | Toyota Camry Cars & Trucks
2005 545i bmw sputtering at 40 miles per hour
So, here's what you have to do - it's a frikkin tranny reset!!
Drive in manual mode M5 for 5 minutes at over 60MPH, then switch it to M6 for 1 minute, then back to M5 for 2 minutes, then back to auto.
Note: the car is going to sputter continuously when you have it on M5 for the 5 minutes.
That was it - drove around for 30 minutes afterwards and no issues what so ever!! Unbelievable!!!
Sep 05, 2012 | BMW Cars & Trucks
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Traction control
This light will come on everytime you loose traction.The computer on the car puts stopping pressure on the tire that is slipping until the slipping is stopped and the correction made.
Dec 31, 2008 | 2007 Volkswagen Beetle
Sony car stereo
If the battery goes dead, click the reset button behind the faceplate with a ball poin pen
Dec 27, 2008 | Sony CDX-M620 CD Player
2005 SATURN VUE stalling at 60mph?
Iit seems that the computer got "confused". A way is to remove the negative battery cable for about a minute then reconnect. This will try to reprogram the computer. If it is still not good, try checking the CPS crankshaft position sensor and the IPS idle position sensor.
Dec 15, 2008 | 2002 Saturn VUE
Blaupunk car stereo
There could be a loose connection somewhere.
Does the sound stops on a regular time interval or only on certain conditions?
Would there be a chance that there's water leakage at the area where the CD changer is stored?
Jun 08, 2008 | Sony XR-C5100 CD Changer
CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
Jan 13, 2008 | Sony CDX-L400X CD Player
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
