Question about Watches
How to remove links from Seiko v172
The links have screws. do I have to use a jeweler's screwdriver?
3 Suggested Answers
SOURCE: Changing links for a Casio watch bracelet
solutions already mentioned(casio wristband) worked for me. However the first link took me forever to remove as I found it hard to envisage what I what attempting. Attached is a pic of a disassembled link which hopefully might help someone....BPB547b9a0.jpg
Posted on Dec 30, 2007
escapement
  • 2334 Answers
SOURCE: I need to remove a link from a solid link bracelet
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have the pins instead of screws.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 29, 2009
I'm trying to find a battery to a Seiko watch, serial # 152635. The case # 8f33-0010.
Take it to a jeweller, $6 to $8 and takes 10 minutes. Most have a screw back. They have the batteries, the tools and the know how.
Jan 05, 2017 | Seiko Watches
What exact battery do I need for Seiko SKA348?
  • Remove back
  • Find battery holder
  • Note battery type
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your Seiko watch to a jeweler who, for a reasonable sum, will replace the battery
ORORO
Nov 22, 2016 | Seiko Watches
My seiko motion clock face opens and does not close back all the time I have replaced the batteries but it still stays open
Thank you for contacting FixYa
I am not as experienced in the clock side of Seiko, but I did find their website and it is filled with great recommendations for clock repair. I would highly recommend you contact Seiko on this.
Best regards. Here is a link to go to:
http://www.seikoclocks.com/#FAQ
Thanks for your rating too!! Jewel
Sep 02, 2010 | Seiko Clocks Melodies In Motion QXM135BRH...
How do i open this thing? pry off or screw off? seiko womens 100m.
I have no ideal. All i know is that it is a Seiko womans watch and Seiko has numerous types of backs on them!! If it has 6 notches on the back, then yes, it is a screw off and it takes a special tool to open the back. Please take to a local jeweler who sells SEIKO to have the battery replaced.
Aug 23, 2010 | Watches
Men's seiko perpetual calendar watch stopped working. jeweler said we had to send it in to the manufacturer...??? what to do?
mcdevito75 here, Your Jeweler had to mention your watch would go to Seiko for repairs. Seiko should notify you or your Jeweler with the repair particulars.
Jun 11, 2010 | Seiko SLL086 Watch
How to shorten band on Rolex submariner
on mine I removed a couple links using a jeweler's screwdriver(flat-blade). Look for the screws in a hole along the narrow edge of the links nearest to the clasp. Use care in removing/replacing these screws, you do not want to break or strip them using excessive force. If you need to remove more than one link, take additional links from the opposite side of the clasp, so the clasp stays centered on your wrist.
Nov 06, 2009 | Rolex Submariner 16618 Wristwatch
Cartier santos links
The links of this watch require special tools and expertise.it's not like a seiko. you should take it to a cartier jeweler I don't think they would even charge you for that.
Oct 01, 2007 | Cartier Santos W20056D6 Wrist Watch
Watches Logo
186 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
