Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
Change from mode 2 to mode 1 - Protocol Manta 4-Channel Radio-Controlled Quad-Copter
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
How do you turn error code light off on a kubota l3901
Mode "A" (Test Mode)
1. While holding down both DPF INHIBIT switch and the parked regeneration switch, turn the key switch to "ON" or "START" position.
2. Mode selection display is indicated on the LCD.
3. Press the parked regeneration switch and the mode indicated on the LCD is changed.
4. If "A" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Test mode is selected.
6. If parked regeneration switch is pressed, the display item is changed.
7. Turn off the key switch to finish test mode.
Mode "b" (Error Information Clear Mode)
1. While holding down both DPF INHIBT switch and parked regeneration switch, turn key switch "ON" or "START" position.
3. Press the parked regeneration switch and the mode indication on the LCD is changed.
4. If "b" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Error information Clear mode is selected and the expression "PUSH" is displayed.
6. Press the parked regeneration switch for more than 2 seconds.
7. The expression "OFF" is displayed.
8. Turn off the key switch.
Be sure to clear error information by performing this procedure after servicing is finished.
Jun 13, 2015 | Kubota Garden
I know the S<->D button that it will change from fraction to decimal, but my calculator happens to change from fraction into scientific notation! i did what the others said to Press SHIFT MODE 2 to...
You want to change the display mode. Press SHIFT MODE. Then press 6 and a number specifying the number of digits after the decimal point for fixed decimal notation, or 6 and 1 or 2 to specify one of the floating point modes.
Sep 18, 2011 | Casio FX-115ES Scientific Calculator
I have a jvc kd-s590 in my car & have no idea how to set the clock. It'd driving me crazy. Please help!
1 Press and hold SEL (Select) for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Set the hour. 1 Select "CLOCK H" if not shown on the display. 2 Adjust the hour. 3 Set the minute. 1 Select "CLOCK M." 2 Adjust the minute. 4 Press SEL (select) to finish the setting. 1 2 During tuner operation: During CD operation: Frequency Clock To check the current clock time (changing the display mode) Press DISP repeatedly. Each time you press the button, the display mode changes as follows. To Cancel Advanced SCM You can cancel the Advanced SCM (Sound Control Memory), and unlink the sound modes and the playback sources. When shipped from the factory, a different sound mode can be stored in memory for each source so that you can change the sound modes simply by changing the sources. LINK ON: Advanced SCM (different SCM for different sources) LINK OFF: Conventional SCM (one SCM for all sources) 1 Press and hold SEL for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Select "SCM LINK" if not shown on the display. 3 Select the desire mode - "LINK ON" or "LINK OFF". 4 Press SEL (select) to finish the setting. • If the unit is not in use when you press DISP, the power turns on, the clock time is shown for 5 seconds, then the power turns off. 1 2
Nov 03, 2010 | JVC KD-S590 CD Player
Intellifax 2820
DR mode means that the distigntive ring feature has been activated so it will not let you change receive mode. You need to turn off DR first. Press menu/set then 2, 0, 2, then press the down arrow till you see distigntive off then press menu/set.
Now you should be able to change the receive mode to fax only!
May 29, 2010 | Brother IntelliFax-2820 Laser Fax
Can I change input mode manually?
Try channel button to 1-2-3--99-98-1-2-3 up & down it should come between 0 & 1
Jan 21, 2010 | Sylvania SRT2232S 32" TV
Can't change to "av mode"
hmmm
i think you must save that in service mode.if not you must find a service
Jun 13, 2009 | Samsung LN-S2651D 26 in. LCD Television
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
67 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
 Russ Hill
Russ Hill
Are you a Protocol Toy Expert? Answer questions, earn points and help others
