Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Where is the belt on the hoover steam vac, how do you change it
What does this cost.
    Problem Solver:
  • 15 Answers
There is no belt. The brushes are ran by an air driven turbine. Make sure the top recovery lid is on correctly and sealed.
Posted on May 25, 2009
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover changing belt
There is no belt in Hoover Steam Vac. A gear box turns the brushes. The nylon gears wear down, eventually, but can be replaced. Check this out: http://www.youtube.com/watch?v=n-vPOk9kEag
Jul 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover Steam Vac Dual V and the brushes no longer turn. Can it it fixed? Model # F7431-900
your belt is probably brokan. underneath the machine you will see some screws carefully take them out writing down which screw went where. than you can pop the plate off and look in there and see if your belt is brokan. If it is the belt number is important to find in your book that came with the machine. hope this helps you.
Aug 16, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
How do you replace the belt on a Hoover steam vac V Model 7425-900 ?
sdHi pdjanusz,
Does yours have a belt on it to change? The Hoover V models have air driven brushes. Can you tell me the problem you're having? Ar the brushes not turning?
Thanks,
Handie andie
Apr 11, 2011 | Hoover Vacuums
How do you get to the belt on a Hoover steam vac?
I hate to tell you, but there is no belt at all on the steam vac line. they have a suction driven turbine to turn the brushes, and a suction driven pump for the water flow. But definately no belts.
If something is not working on it, describe more in detail what is not working and we can narrow it down better for a proper solution.
Nov 06, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Solution for "the unit is making smoke rubber belt smell how do i change the belt...hoover steam vac f7225-900
there is no belt on this model. From your description, it is definitely electrical, possibly the motor. I would have it looked at a repair shop.
Mar 15, 2009 | Hoover F7225-900 SteamVac V2 Upright...
How do i change the belt on a hoover steam vac ultra
Are you sure there is a belt in there? Here is a schematic.
http://www.vacshopusa.com/pdf/hf5837900.pdf
Any good vacuum repair or sales shop that does Hoover should be able to order you any part
Jan 03, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover F5914 SteamVac Deep Cleaner
There is no belt on this model. what is your exact problem?
Nov 06, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover F6025900 Steam Vac Widepath LS, I own this steam vac and I found bits of rubber under the machine when I turned it on, smelled like burned rubber from a belt? Can you please tell me if there is a...
Well there is no belt, and not sure what the rubber would be from, everything is plastic or metal. Unless it is really an electrical smell, which means the motor is going bad.
Jun 22, 2008 | Hoover Vacuums
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
226 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
