Question about Measuring Tools & Sensors
Gatehouse door lock will not auto lock - Measuring Tools & Sensors
We have a gatehouse model # pl110s10 and are unable to program a code because we got rid of the box. Can you help us program a code?
the programming instructions are inside the battery cover. instead of Enter click the Gatehouse button in some cases. also, to actually USE the thing, you just enter your code and hit Gatehouse/enter to unlock, and just hit Gatehouse/enter to lock.
Mar 22, 2015 | Televison & Video
How do you install these? I put one on according to the diagram on the package and the lid will not close.
I am experiencing the same problem...I have even looked online for different installation videos....nothing doing. I need to install them asap but keep running into the same problem. I have adjusted my mount placements a number of different ways and along with suggested diagram...nothing is working.
Dec 25, 2013 | Gatehouse Antique Brass Left Spring Lid...
Have deadbolt lost template for install
Control of uncertainties is not possible because it's the natural truth. You can borrow deadbolt from the locksmith in san francisco or can hire them to fix it as well.
Nov 03, 2013 | Gatehouse Locks & Locksmithing
How to remove gatehouse door knob?
Look for a small set screw on the side of the deadbolt on the inside of the door loosen the set scrww and remove the cover to expose the screws that hold the door knob on
Oct 31, 2013 | Gatehouse Springfield Satin Nickel...
B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728: Gatehouse deadbolt 2 tears old.moves about 1/2 inc...
Remove, lubricate with a dry silicone or graphite lubricant and reinstall. The mounting bolts may have loosened up, and now it is not perfectly lined up. More likely is some corrossion or wear in the throw mechanism.
May 16, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have several ''gatehouse'' deadbolts and i can't get the core out in order to rekey them. how can i get it out or find instructions?
Here is a link to the manual for rekeying all Schlade/Gatehouse locks.(It's in PDF format)You can download,save,print,or view online.
Please take time to rate this fixya
May 14, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Need to know how to adjust the door auto lock function.
Not an easy fix! The door lock function was designed to lock doors only. you can however, disable this lock feature by simply cutting the light blue automatic door lock signal wire on the 6-wire harness plug connector located on the chime module (In component center).
Mar 15, 2009 | 2005 Toyota Camry Solara
Measuring Tools & Sensors Logo
47 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
