My central cooling system does not work. Every things is working accept a compressor. When I turn on the cooling system the compressor makes strange nose and after one minute it turns off, but fan kips continue to work. Do you have any suggestions for me? Thank you Model # of my air conditioner is CCU10A42A-1
  • ikotyay May 18, 2009
    What should I do in this situation?
  • jessnjessmom May 19, 2009
    when i turned on my unit today it was making a loud revving noise kinda of also. cool air was coming out of vents and left i home. i returned after and 1 1/2 and the unit is not on but cool air is still coming out of the vents although the house hasn't cooled down at all. the furnace is making noise still but nothing from the unit itself.
  • 148 Answers
Compressor overload on the compressor
Posted on May 17, 2009
  • Jason vangel May 18, 2009
    should get a technician to replace overload
I have central air and I was wondering how do you put freon in it because its not blowing out cool air
Is the compressor starting? On the outdoor unit you will see a large copper pipe and a small copper pipe. Is the larger of the two cold to the touch? wet? Just because a central air system is not blowing cool air does not mean it needs freon. If you have clogged filters it cannot do an air exchange. So, I would recommend checking the easiest things first before adding Freon.Most people make the mistake of adding Freon and overcharge their system. In a low load situation you can slug the compressor with liquid and your system is ruined. If you do have to add Freon it indicates that you have a leak. An AC System is a closed system and if it is working properly you should not have to add Freon.
Aug 03, 2011 | Whirlwind FH-778 Air Conditioner
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
Model ATB2136ARS My refrigerator is working just fine, but it keeps making a clicking noise. The clicks are becoming more frequent.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 18, 2011 | Amana ATB2136ARS 33" Top Freezer...
Goodman central air conditioner not blowing normally
It sounds like the compressor is not coming on in the outside unit. If it worked fine and was cooling before, then your compressor probably over-heated and tripped the internal overload switch which causes it to stay off while everything else is working. The most common cause of your compressor over heating is an incorrect refrigerant charge, though it could be a few other things like a restriction in the copper line set. You will be able to hear the fan motor and the compressor kick on if you listen close while the system first turns on. If the compressor is over-heated, then after it cools to a save temperature, it will come on again, but only till it over-heats again. I would have the charge checked on the system, but remember that if the compressor is over-heated when the technician gets there, there is nothing he can do until it cools down and time is money! It's best to not run it until the problem gets figured out. Hope this helps and points you in the right direction. Good luck!
Jul 17, 2010 | Heating & Cooling
Not cooling or sounding like it's not running
There's a lot of things that could cause this. Make sure the fridge is plugged in and receiving power, make sure the thermostats are set properly, If it's electronic, look for a reset button, unplug it for thirty seconds and plug it back in, failing that unplug it for like 2 minutes and plug it back in. If none of that works you'll need to check the compressor. It may be a failed breaker or fuse, or may be a problem that needs repair.
Oct 11, 2009 | Amana ATB2132ARQ 33" Top Freezer...
Strange fridge problem - GE GSL25JFTBS
Not enouch or to much GAS in System or problem whit part called (starter).Next thing could by blocked capilara this tid wire connected to filter or filter by self.
Aug 04, 2009 | GE CleanSteel GSL25JFTBS
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
Central air and heating, not cooling
Need to have checked out by a diagnostic ac man.
Aug 08, 2008 | Haier Energy Star ESA3183 Air Conditioner
Not cooling
every single component in your cooling unit is needed for it to work, so anything can shut it down. If you could provide more information as to what type of unit you have: is it a central heat and air package unit? or central split system (furnace indoors and condenser outside)? or a wall a/c? Does any part of the system/unit do anything?
Apr 27, 2008 | Heating & Cooling
Heating & Cooling Logo
299 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
