Question about Gaggia Classic Espresso Machine
No steam Hi -- my 10-yr-old Gaggia Classic was working perfectly the last time I shut it off. Today, when I turn the steam knob, there is no steam, no sound, nothing. Coffee-maker is working. Pump is primed. thanks, Carolyn
  • carolynvoxfe May 18, 2009
    thank you -- after i emailed you, it occurred to me that the steam wand might be clogged, even tho' i'm very careful about cleaning it.
    I found something small enough to insert, and it instantly unclogged!
    many thanx for motivating me to find a solution.
    Carolyn
    p.s. i'm impressesd with the efficiency of your service/site.
    President:
  • 1,618 Answers
Is the coffee hot or cold?
If hot then the steam wand is clogged, try inserting a paperclip in the hole(Remove the parnello black plastic covering silver steam wand) at the end of the nozzle.
If cold then the element is not heating, if you remove the top panel on the machine there is a thermostat on the boiler. That might be damaged, some of them are resettable (it will have a red or brown pin in the middle) if it is a resettable one then push in the pin, if not then it will have to be replaced.
Posted on May 17, 2009
Steam valve knob is stuck
The only reason for this I can think of is that the water has allot of minerals in it and they are depositing on the valve, use purified water from now on.
Nov 10, 2016 | Gaggia Coffee Makers & Espresso Machines
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Gaggia classic steam knob
Have you turned the steam valve off tightly and cracked the knob inside allowing it to turn on the brass spindle.Try pulling the knob off and turning the spindle with a pair of pliers or a small adjustable spanner.If the spindle keeps turning you may have sheared the spindle off inside.If this is the case you will need a new steam valve complete as they are not repairable.Steam valve cost about 35
Tools required 5 mm alan key and 17 mm spanner for steam pipe
Jun 16, 2012 | Gaggia Classic Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Hi, my 4 year old gaggia classic coffee machine's steamer no longer works. The coffee bit still works fine, but when i twist the knob to let the steam through, nothing happens. Can this be fixed easily?
It could be that the nozzle is blocked, and or the steam valve is blocked. Try descaling machine, if that does not help then you might have to remove steam valve to make sure it is not blocked.
Jul 02, 2010 | Gaggia Classic Espresso Machine
I have a 5 yr old Gaggia Classic and it is due for a service any suggestions
Descale boiler, replace all the O-rings and gaskets(boiler gasket, group gasket, o-ring for the steam valve boiler connection, and the o-rings on the solenoid and expansion valve."
Apr 14, 2010 | Gaggia Classic Espresso Machine
My gaggia classic frother is stuck and cannot turn the black knob
pull the knob to you, take it out than grab the valves axe with wrech or pliers, to prevent braking the black knob and open the valve.
after you opened it once it should work perfect.
ps these valves seal metal to metal and when thay stay long without working thay can do this.
Mar 09, 2009 | Gaggia Classic Espresso Machine
Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Feb 03, 2008 | Gaggia Classic Espresso Machine
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Gaggia Classic Espresso Machine Logo
299 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
