Question about Samsung Galaxy Note 10.1
Galaxy note 10.1 running slow and freezing up
Frustrating I can type the words before they hit the screen, very slow
How can I see what Iam typing when the keyboard hides the typed words?
Terence, i've got android. I don't know if it would work in your system but what about deleting it and immediately reloading...?
Or the answer lies in the settings...
May 06, 2016 | Apple iPad Tablets & eReaders
Every time i try to type a word to down load a app on the google store it clicks to the home screen.
when typing in the name off app on the keyboard you type on Press the ENTER button and not the home button on tablet .
Dec 28, 2015 | Iview 7" Android 4.0 Tablet PC Model:...
Why is all my information and all of my tabs ect. No longer in english? I cant navagate through my settings or anything because i cant read it
it all depends what version of android you have if it is 4.0 or 4.1 the settings are at the bottom of the screen, hit the settings (1), to open the settings panel, hit the languages and input icon (2) to open the languages panel. , hit the top one it says language in whatever language is set ,Look for the word ENGLISH and you will be all done. re-start your device and that is it
Apr 25, 2015 | Nextbook Premium 8 Se Android
MY RCA TABLET TOUCH SCREEN ISNT WORKING AND THERE IS A CRACK UNDER THE SCREEN
the LCD seems to be damaged, check on Ebay, type in the exact model and you should find it. it has to be replaced.
Feb 05, 2014 | RCA REB1200
Download google play
1chek memory if you have inoughmemory spece 2check for firmware update.if all its okey and you stil have problem with it.folow me...with pc.go to google download kies for Samsung 2install it.3check debuginging inthe phone setings 4connect your phone with USB cable now you're good toGO if your phone its OEM.(original manufacture)you'll see some thing like a box down the screen
Nov 14, 2013 | Tablets & eReaders
On Skype, how do I get it to stop changing the words I type and how do I use the ones that pop up?
hit the x in the white box that pops up with the corrected word, the ones that pop up, just hit space and it will fill in for you
Jan 10, 2011 | Apple iPad 64 GB WiFi
Acer travelmate c110 blue screen , how to fix it
If windows won't boot and if you have tried the safe mode and "Last Known Good Configuration" mode, then try the procedure below and repair the windows installation files.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Jan 15, 2010 | Acer TravelMate C110 Tablet PC
Tablet pc rotation
u can use once time alt+ctrl+ any type arrow to roated screen
Jan 24, 2008 | Toshiba Tecra M7 Tablet PC
Open Questions:
See all Samsung Galaxy Note 10.1 Questions
Samsung Galaxy Note 10.1 Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
