Question about HP w1907 LCD Monitor
I installed w1907 monitor all fine except now I have no sound
I have installed without installing the DVI as I did not know what that was. However everything looks great but I have absolutely not sound. I have tried everything ...its gone.
    Novelist:
  • 118 Answers
DVI is a hardware interface. It's a type of plug.
Does your monitor have speakers built into it?
On many computers, the output for the sound is very near the output for the monitor. Is it possible that you loosened the wire for the sound when you installed the monitor (plugged it in), or unplugged the sound altogether and plugged it back into the wrong place? The outbound sound hole on most, but not all, computers is green.
All computers have at least two places to plug in sound, most have 3, and the newer machines have 6. If you are unsure which is the correct hole to plug that sound wire into, you can play something on your computer that makes sound for a while (like a song) and move the plug from one to the other until sound is heard.
If you have 6 holes that the sound wire fits, you most likely have software on your computer that pops up and tells you were you have plugged it in.
If the speakers are built into the new monitor, check the monitor for controls and ensure that the volume controls are not all the way down.
All of these solutions are hardware solutions. Now, we have software solutions:
Open the control panel and find Sounds and Audio controls. Open that.
Check to see that nothing has "mute" checked.
Check also to see that the sound levels are high enough to hear something.
Good luck.
Posted on May 17, 2009
Installing new Samsung BX2250 21.5 widescreen monitor, don't have the appropriate DVI outlet on my computer to match HDMI to DVI cable supplied with unit. Monitor is stuck on "Check Signal Cable...
Your monitor has Analog RGB, DVI and HDMI inputs. Any other hook ups will require additional cables and/or adaptors. It also has 2 additional audio inputs. I can't answer your question without knowing what kind of outputs you do have on you computer system. Most desktops have DVI out and would probably be your best bet using a DVI to HDMI adaptor with a HDMI cable out to your HDMI in on your monitor.Rgb cable would use svga out on your computer. The best way to get an answer would be to let me know the make and model of your computer system with avaiable outputs, if you know what the outputs are or, repost with additional info included.
Dave
Apr 30, 2011 | Samsung Computers & Internet
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
My monitor will not allow me to even get a menu screen with the computer off. How can I get it reset back to factory settings without accessing the monitors menu? Should I just get a new monitor?
What is wrong with your hp w1907 lcd monitor? It won't allow you to get to the menu screen with the computer off?
The computer must control the monitor and should have a graphics card that supports the different resolutions of the monitor which will be connected to the computer via DVI or VGA.
I think your monitor is fine, unless you cannot get it to work with your computer.
Good luck on getting your monitor to work on your computer.
Jan 02, 2011 | HP w1907 LCD Monitor
Monitor (hp w1907)
Pls power on your PC & press F8 button continously then you see last known good configuration option. select your option & press enter. i hope your problem will be solved.
Nov 13, 2009 | HP w1907 LCD Monitor
Basicaly the sound doesnt work, but it says their is no
If it worked fine yesterday try doing a system restore to previous day.
Jun 03, 2009 | HP w1907 LCD Monitor
HP W1907 Monitor
If it was working fine why install additional software? Try booting into safe mode and uninstalling the software or drivers.
Jan 03, 2009 | HP w1907 LCD Monitor
HP w1907 monitor driver software will not load
"Access is denied" is the key here. It sounds like your login in windows does not allow you the privileges for that installation. Try logging in as an administrator and re-installing. One thing bothers me though, if this was purchased as a system, why would you need to install drivers? that should have been pre-installed.
Dec 14, 2008 | Computers & Internet
HP w1907 LCD Monitor Logo
181 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
