Question about Black & Decker String Trimmer Cordless 12" 18V
Need handle for cst2000 , grass hog string trimmer
  • 313 Answers
SOURCE: CST2000 Grass Hog Cordless Trimmer/Edger stops working until shaken
open up the motor housing maybe loose connection between the terminal & motor. for parts & diagram see www.dewaltservcienet.com look for the icon find it now & enter the model #
Posted on Jul 26, 2008
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
  • 133 Answers
SOURCE: I have an Electric grass hog dual string trimmer.
Wind the strings in the direction of the arrow on the spool.
Posted on Apr 20, 2010
SOURCE: string will not advance on black and decker grass
Is it best to buy a spool for Grass Hog, than trying to re-string myself? String seems to get stuck.
Posted on May 23, 2010
  • 903 Answers
SOURCE: ;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
Posted on Jul 10, 2010
It does not turn on even if it was charged for 24 hrs
When it charges, does the red light come on on the charger? Some of the CST2000 chargers make bad connections, and they don't actually charge.
Make sure the red light is coming on when you're charging the battery. If the light is coming on and you still can't use the trimmer after charging, you'll need either a new battery or a whole new battery pack (the black handle of the trimmer).
Hope that helps!
Sep 04, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How long does the trimmer last on a charge?
how long is a peice of string!!!!! how oftern do you use it as the charge will always die what ever
Jul 16, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How to put together the CST2000 and install a battery
Which part of the Grass Hog did you take apart? If you mean the spool head, that is easy to reassemble. The actual spool (the round part with the line coming out) goes into the cavity on the bottom of the trimmer, with the line poking out of the hole in the side several inches (not enough to hit the plastic guard). Then the cover (orange with the spring on it) fits on top of the spool so that the spring pushes on the spool and the two tabs on the side snap into the holes in the trimmer.
Unless you took another part off, that should be all you need to do to reassemble the Grass Hog. Turn it right-side up and turn it on to make sure everything works.
Jun 01, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Have a cst2000 but do not have the charger
The charger for the CST2000 is part #243248-00, but it is obsolete now. You could maybe find a used one for sale on eBay or craigslist, though.
Apr 17, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
I don't need a manual - I need a replacement handle
if your refering to the batt handle then its a obsolete item with no replacement part number. your part # is 243215-00 and your best bet is to sell it or put lots of ducktape or epoxy or keep checking ebay
Jul 09, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
Weed whacker
I was unable to get that ring off also... I was able to pull plastic side apart far enough to pull motor out and "rewire" it. Even fit back in when I was done... just barely. and was very gentle...
I do not know how to get the ring apart, though.
Feb 01, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
Jul 14, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
96 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
