Question about Grace QuiltMotion Professional Computer Automated Quilting System Compatible For Sewing Machine: Janome 6600
The needle is stuck in up position and will not move down
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Nov 01, 2016 | Bernina Sewing Machines
Needle is stuck in down position and manually the wheel won't move
Try removing the bobbin case. Usually the thread is holding the needle in place, therefore the hand wheel will not operate. Once you get the thread released, it should all come free.
Sep 15, 2016 | Simplicity Sewing Machines
Needle stays down, will not come up.
sounds like the machine froze up, machine needs to be serviced
Sep 25, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
Mar 09, 2014 | Brother Sewing Machines
Presser foot stuck in down position
There could be a piece of the needle stuck in the bobbin area, try sliding the base plate off [not easy with the foot down i know] and see if you can clean it out.
Jan 21, 2014 | Sewing Machines
The needle threader is stuck down on my Emerald 116
Typically the threading device moves downward and then rotates sideways. Which function is stuck? Is the shaft bent? In any case, the threader apparatus is removable. If you need help disassembling, get a service manual for that model (probably about $20 on the internet).
Feb 11, 2013 | Husqvarna Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Wheel won't move
it's possible that something has come loose or broken, it needs to be serviced
Jan 24, 2012 | Euro-Pro 9130 Sewing Machine
Grace QuiltMotion Professional Computer Automated Quilting System Compatible For Sewing Machine: Janome 6600 Logo
13 people viewed this question
Top Grace Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Grace Sewing Machine Expert? Answer questions, earn points and help others
