Question about Kamp Kitchen 30 QT. Stainless Steel Turkey Fryer
How to light the fryer - Kamp Kitchen 30 QT. Stainless Steel Turkey Fryer
Yesterday my fryer started shooting flames out of the fryer. What is the problem?
Check for loose or broken gas line connectors, including the pilot line. Check for blockage in the flue in the back of the fryer. Things occasionally fall down there and people with the bad habit of banging the fry baskets on the top of the flue will eventually clog it up with food particles and carbonized grease. Check for a defective gas pressure regulator, which can cause excessive gas pressure getting to the burners. Check to see if the burners are properly in position and that the holes in the burner are not blocked by soot or grease.
You may be able to check these things by having one person very carefully open the main gas shutoff just enough to for a second person to try to light the fryer. Before attempting to light the fryer listen and smell for escaping gas. If the fryer lights, observe the fryer while the first person very gradually opens the valve further. This can be hazardous, and the person observing should stay well back and the person on the main gas valve should be ready to close the valve.
Personally, if the problem is not obvious, like a loose of broken gas line or a blocked flue, I would leave further testing to a qualified service provider.
Sep 21, 2014 | Kitchen Appliances - Others
Deep fryer pilot light switches off automatically
First make sure that the thermocouple tube is directly in the pilot light flame. If it is, then the thermocouple is defective.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
The pilot is on but the switch won't turn the fryer on. The gas is on but it just wont fire up? Dean Fryer
I can tell you from my own experience with fryers, that they take quite some time to heat up....before lighting.... The probe takes some time to get hot, before it will kick on and light. You normally have to hold the light button on for some time, before the manual fryers will light. I have helped many a customer who cannot seem to get their manual gas fryers to light, and normally it's because they don't hold the light button down long enough. The sensor in there takes alittle time to heat up and it tells the fryer it's time to light. I think people get alittle scaried with gas and just don't hold it down long enough. Try holding that button in longer first, then light it... It should work. If not, call us and we'll try to walk you through it.... Our service tech is Ray, and I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959. Thanks and good luck, Susan
Sep 10, 2011 | Frymaster Dean 2424G Deep Fryer
I have the AF45 fryer. I cannot light the pilot on this fryer. I have tried all possible solutions to this but still wont work.
Normally, on manual gas fryers, people don't hold down the light pilot button long enough for the sensors to heat up, to tell the pilot to light.... That's our number one complaint, and number one service call, and it's almost always the same thing;..... Hold the button down much longer, then try to light it... If you still have trouble, call our service tech, Ray @ 888-542-5959, at Restaurant Equipment Outlet, Cincinnati, Ohio. Thanks, Susan REO
Jul 16, 2011 | American Range AF45LP Deep Fryer
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
Fryer wont fire up
Check the continuity, flip the switch on and off using an ohmmeter, if the switch is ok, check the thermal fuse inside.(you have to open the unit) replace whatever is defective
Jun 28, 2009 | Pitco Frialator SG14 Deep Fryer
Shallow fryer pilot light goes out
Call fafctory service dept 800-637-9188 ext 22
May 27, 2009 | Comstock-Castle 14HF Deep Fryer
Hw do I light the GF-8 countertop deep fryer?
Hello. This is what you need, here is a link to a gf-10, it is close enough to get you going. The directions are on page 4, picture of the valve on page 5:
http://www.cecilware.com/docs/N797A%20GF-10%20Manual.pdf
Hope that helped, and thank you.
If you have further problems, "ask me"
Apr 14, 2009 | Kitchen Appliances - Others
My Cecilware GF-10 LP deep fryer the pilot will not light.
on that cecilware fryer there is a regulator to the right of the pilot light unsrew the aluminum cap and take off cap then you will see a white plastic screw turn that screw clockwise until it stops this will give the fryer more gas this could be your problem the regulator is silver and inline with the gas pipe comming from the back
Nov 21, 2008 | Cecilware GF-10 Deep Fryer
Kamp Kitchen 30 QT. Stainless Steel Turkey Fryer Logo
43 people viewed this question
Top Kamp Kitchen Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kamp Kitchen Kitchen Appliances - Other Expert? Answer questions, earn points and help others
