Question about Clarion NX500 Car Video Player
Radio works but you can only see clarion on screen
Why is the screen not coming on my Clarion vz401 Clarion but I have sound and everything else works
If you have a blank screen while listening to an audio source (Radio, CD, USB, etc.) the interconnecting ribbon cable that goes from the system board to the display module could be damaged/cracked and needs to be replaced.
Mar 24, 2016 | Clarion Car Audio & Video
My clarion car radio screen is cracked really bad tv and stereo still work can i just replace the screen
Well if only the screen is cracked it is possible to only replace the screen but if the necessary part, in this case "the screen" , if it is not available in a store then your mechanic or you won't be able to replce the broken screen but rather change the whole device.
Mar 08, 2015 | Clarion NZ503 In-Dash 7" LCD Touchscreen...
Clarion NZ500 nothing on screen
Clarion ebrake safety bypass without using toggle switch
Clarion has a brake safety wire that has to switch from open to a ground every time you turn on the unit so therefore you cannot just ground the brake wire it has to switch to ground every time you turn on the radio
Aug 22, 2017 | Clarion NZ500 Car Video Player
Clarion nx501 with hino and password
i hAVE the same exact issue and the 4 digit password to unlock it is the last 4 numbers the HINO trucks V.I.N... they say u only get 3 tries and it locks it and the only way to unlock it is to contact clarion... lick my balls clarion the default password is 0000 and u get 3 tries but just disconnect the power and reconnect the power and BAM... you will be asked to enter a security code all over again...0000 that is your unlock code.
as for the start- up HINO screen... good luck. its called a splash screen and you would have to hack clarions firmware in order to do so and i suppose if you were able to locate the internal hard drive but even then. clarion invested billions to protect their operation systems in their devices. i think the image is burned into the chip where the head unit was sent from a hino dealer brand new in a box directly to clarion's I.T. to have changed cause it comes factory as a clarion boot screen.
you will also notice that the hint clarion nx501 wiring harness is altered so to make work in that truck that only comes with two front speakers.... the rear speaker leads are nowhere to be found; GONE like a new brides panties!.. you also won't have any rya leads ect.. gay gay situation and if u figure out the splash screen change let me know.
peace.
S.D
Jan 16, 2013 | Clarion NX501
Hello, i have a clarion xmd3, i bought it in 2004 and have a sirrius add on sara radio reciever. im trying to resubscribe for service. i need the radio to display sat radio id#. went to clarion web site...
You can get the # right off the Sirius unit (it's on a sticker on it - SID#).
Also try going between channels 1 and 184 (IE go track/tune down) it may show up then.
If not press and hold the T button for longer than 1 second. Then use the track up/down buttons to scroll through the menu. There should be a screen that will show Sirius or Sat ID or something to that effect. When you see that press the up or down button, or play pause and it should display it.
Let me know if that works.
Dec 11, 2010 | Clarion XMD3
Can you recode clarion radio for peugeot 406 hdi
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then it will only be available from your Main Dealer or a Decoding Service
Jul 08, 2009 | Clarion SIR-CL2 SIRIUS Radio Receiver
Clarion NX500 Car Video Player Logo
22 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
