Question about Car Audio & Video
I have a kenwood krc-557l and dont know what wires are what...
Can you help please, i know which ones are the speaker wires but there is a black wire, red wire, yellow wire and blue wire left over. Also, on the speaker wires, one has a line on and one doesnt on both sets...which is negative? the one with the line on?
  • Tim Stanton May 20, 2009
    thank you very much...i will pass this on to my fella and see if it works. Many Thanks :-D
    President:
  • 1,114 Answers
Red is "Key on Pwr"
Yellow is "Constant Hot" always powered
Black is "Ground"
Blue is "Pwr antenna or amplifier remote turn on"
This is tapping my memory a little, however, I believe stripe is positive on Kenwood and solid is negative. The easiest way to test spkr wiring is to connect your pwr,gnd,etc. then make sure all other wires are individually taped barring one. Use any speaker, turn on the radio, connect one wire to pos & one to neg on spkr, look at the cone of the speaker, if it pops out, you have the correct wiring "in phase" if it's incorrect, the spkr will appear to pop "in". That's "out of phase" reverse your wiring.
Hope that helps
Posted on May 17, 2009
Kenwwod KDC MP 543u Protect mode problem
This indicates a short in one of the speakers, or possibly the speakers are not wired correctly. Please see my tip at http://www.fixya.com/support/r9389300-stereo_says_protect_or_clicks_off_when .
Correct wiring for 95 Corolla is as follows:
1995 Toyota Corolla Wiring harness, Kenwood wire color
Radio Constant 12V+ Wire: Blue/Yellow, yellow
Radio Switched 12V+ Wire: Gray, red
Radio Ground Wire: Brown, black
Radio Illumination Wire: Green, not used by Kenwood--please tape off
Radio Antenna Trigger Wire: Black/Red, blue
Left Front Speaker Wire (+): Pink, white
Left Front Speaker Wire (-): Purple, white/black
Right Front Speaker Wire (+): Light Green, gray
Right Front Speaker Wire (-): Blue, gray/black
Left Rear Speaker Wire (+): Black, green
Left Rear Speaker Wire (-): Yellow, green/black
Right Rear Speaker Wire (+): Red, purple
Right Rear Speaker Wire (-): White , purple/black
Dec 29, 2011 | Kenwood Car Audio & Video
I please need a kenwood kvt 516 wiring diagram to hook up my stereo i dont know what each color is. like left fron speaker etc. please help
battery yellow
accessory red
ground black
power antenna blue
amp turn blue/white
illumination orange
dimmer orange/white
RF + gray
RF - gray/black
LF + white
LF - white/black
RR + violet
RR - violet/black
LR + green
LR - green/black
Sep 27, 2010 | Kenwood Car Audio & Video
Looking for a wiring schematic for a kenwood kdc-mp425 deck. I can see the speaker wires. Trying to figure out which is my constant and switched 12v wires. I have 6 other wires besides my 8 speaker ones,...
Red is usually 12v switched and yellow is constant.I have done many brands and that is the norm but I have not done Kenwoods.Here is a link though.I couldn't find yours but did find a 435.Makers usually stick with the same colors year after year so it should not be an issue.The print is small and i couldn't find a way to largen it.
http://www.retrevo.com/pdf/468dj981/13/Installation#q=Kenwood+KRC-435
This is their home page as they have many things and I use it for all sorts of stuff.
Good luck! Greg
Sep 21, 2010 | Kenwood Sirius KDC-MP425 CD Player
How do i connect a kenwood krc 394 radio cassette,+ve battery, eth, and speaker connections.
Head unit color code:
12V-Yellow
12V switched-Red
Ground-Black
Illumination or Dimmer-Orange/Orange w/white stripe
Blue-Power Antenna
Blue wwhite stripe-Amp turn on
Whites-FL speaker
Greys-FR speaker
Greens-RL speaker
Purples-RR speaker
(Black stripes negative)
If you have a female harness to connect to the veicle side you will pretty much color match. The only exception is that you may only have an amp turn on wire but only a power antenna on the vehicle. In this case you would connect blue w/white stripe wire from radio harness to the blue antenna wire on the vehicle side.
If you are doing a hardwire (factory plug has been cut off) you can obtain a wiring code for your vehicle at www.the12volt.com for most vehicles.
Jun 06, 2010 | Kenwood KRC-394 Cassette Player
Wiring diagram for Kenwood KRC-2007?
red wire is key source black wire is ground yellow wire is menory 12 v source is that is on all time rest are speaker wires make sure u put the full color wires as ur pos side then the wires with a blk line thur is neg side
May 15, 2010 | Kenwood KRC-2007 Cassette Player
I HAVE A KENWOOD KRC-2007 CAR STEREO AND DON'T KNOW WHICH COLORED WIRE GOES TO THE LEFT AND RIGHT FRONT SPEAKERS, I THOUGHT IT WAS WHITE/WHITE BLACK AND GREY/GREY BLACK.
Hello! Front Right; + = Grey... - = Grey/White
Front Left= + = White... - = White/Black
You are correct...Perhaps you need the vehicle's colors?
If so send a comment with year, make and model...
Guru.....saailer
Feb 17, 2010 | Vehicle Parts & Accessories
Need wiring diagram
KRC-379r is not on Kenwoods website, however, They haven't changed much in 20 years either.
Green is Left Rear +
White with black is Left common(-)
White is Left front+
Purple is Right Rear +
Gray with Black is Right common (-)
Gray is Right Front +
Red is Key on 12v
Yellow is constant 12v
Black is Chassis Ground
Blue is Amp/Pwr Antenna Trigger
Hope this helps.
May 25, 2009 | Kenwood KRC-379R Cassette Player
I have a kenwood krc-3005 radio I do not have a wire diagram can you help
Yellow (+) Constant 12 Volts
Red (+) Switched 12 Volts
Black (~) Ground
Blue w/white stripe (+) Remote Out(used to turn
on the amplifiers)
Orange w/white stripe (+) Dimmer IN(used to dim
the display of the unit)
NOTE. if you dont want to hook up this wire it doesnt matter)
SPEAKERS OUTPUTS
White(+) Left Front
White w/black (~) Left Front
Gray (+) Right Front
Gray w/black (~) Right Front
Green (+) Left Rear
Green w/black(~) Left Rear
Purple (+) Right Rear
Purple w/black (~) Right Rear
Jan 04, 2009 | Kenwood KRC-207S
Need wiring schematic for Kenwwod KRC-2000 cassette receiver
Yellow : Battery - should have a 1A inline fuse - (memory)
Red : Ignition - should have a 5A inline fuse - (power)
Black : Ground (chassis)
Light Blue : Power antenna
Green : Left Front Speaker
Orange : Right Front Speaker
Blue : Left Rear Speaker
Red : Right Rear Speaker
Gray : Common ground for all speakers
Hope this helps.
Nov 12, 2008 | Kenwood Audio Players & Recorders
Kenwood krc 479r
If there was no spark and wires hooked up wrong in the first place, your player should work if you find the PWR lead and the Remote lead and ground. Then speaker wires +) and (-
Sep 25, 2007 | Kenwood KRC-479R Cassette Player
Car Audio & Video Logo
114 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
