Question about Relic Watches
Relic watch zr15668
How to adjust band
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
SOURCE: Need to replace band on Relic ZR50003/1200607 watch
Hi i need to change the band in my watch any idea how to do it ?
Many Thanks
Wiola
Posted on Sep 29, 2008
SOURCE: need to adjust watch band
how to adjust a man's beverly hills polo club watch band
Posted on Dec 25, 2008
  • 183 Answers
SOURCE: how to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Posted on Sep 19, 2009
Testimonial: "looks like you were right!"
disap1
  • 98 Answers
SOURCE: How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Posted on Jan 09, 2010
I GOT A ZR11811 WATCH FOR XMAS AND BAND IS TO BIG IT IS ARELIC BRAND
Take it in to your local watch repair shop, they have the required tools in most cases to make the adjustment.
Dec 28, 2010 | Relic Watches
I have a Relic watch that is probably 20 or 30 years old. It still runs well, but the bracelet band is broken. I live in Monroeville, PA. Where can I get the band replaced?
mcdevito75 Here, You can go to Ebay or simply look for a small watch repair shop in your area for a new Bracelet for your Reic watch.
Sep 24, 2010 | Relic Watches
Jan 09, 2010 | Relic Watches
How to make a relic watch bracelet a little smaller?
Sep 18, 2009 | Relic 0504648FA
Need to adjust watch band
Aug 23, 2008 | Relic 0504648FA
Many Thanks
Wiola
Mar 11, 2008 | Relic Watches
Relic Watch Band Removal
If there are holes where the band connects to the watch and you are unable to push the spring bar out. There may be a bar connecting the band to the watch. Those are harder to push out.You might have to use a tool & hammer it with a gavel. Hope this helps
Mar 04, 2008 | Watches
Adjusting the watch band on a Relic Adjusta Link Watch
have heard to call relic 1 800 842 8621 and they will send up to two links i think with no charge just shipping
Jan 27, 2008 | Watches
Watches Logo
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
Jim Parker
Jim Parker
Are you a Relic Watch Expert? Answer questions, earn points and help others
