Question about Essick Air Humidifiers
How to locate the serial number - Essick Air Humidifiers
Heater comes on but quickly goes off even after
This sounds like the flame sensor which sometimes can be fixed by taking them out and gently sanding them off to get the build up clear. If it is this, it will be located in front of one of the burners. It could also be a couple other things, but without a model number or anything, I'm not real sure what you are working on. Hope it helps.
Mar 09, 2010 | Humidifiers
Can i fix the fan on my dimplex dac 9005 portable
1. Disconnect the dimplex aircon from the power source.
2. Dismount the motor driving the fan from its mounting.
3. Mark the motor lead wires accordingly.
4. Disassemble the motor, and replace the bearings.
(Take note of the bearing number located at sides)
5. After replacing the bearings, assemble the motor,
and have it remounted in place.
6. Reconnect the wires and palce an electrical tape
at the bare joints.
7. Conduct a test run of the unit..
Hpoe this helps.
Jan 05, 2010 | Humidifiers
Fuel filtrer. i'm trying to find where it is located on 1991
Fuel travels from the gas tank in the rear via the pump located in the tank. The fuel line travels under the driver's side of the car up into the engine bay, then enters the fuel filter, which is located on top of the driver's front fender in the engine bay. It's about the size of the bottom of a beer can and then the fuel heads on into the injection system on the engine.
'robzzz' (www.twinturbo.net)
Jul 29, 2009 | General Filters 1137 Humidifier
Refrigerator honeywell model number 88031 melted circuit board! Where to get parts?
any refrigeration supply company could order that part for you just give him model and serial numbers of the refrigerator and number on the board and they can help you
May 13, 2009 | Honeywell HE365 Humidifier
Heating does not work in Danby 3-IN-1 Home Comfort Unit
Called Danby, and the Unit is under warranty. They gave me the name of someone local who will fix the unit under warranty. The only problem is contacting the person. Voice mail is full.
Thank you
Feb 02, 2009 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Pressure switch
Hi AB, I am mr.grzz,
thanks for your questions, well first off there is no fixing the pressure switch, it will have to be replaced, you will need your model and serial number on the furnace, make of furnace, to order a new one from a parts supplier, fairly easy to replace.first make sure the power is off to the furnace, undo the two wire leads on it, then the two screws holding it in place, remove the one or two small hoses attached to it, if you remove it before you go to look for a part, that would be best, there is a rating on it, just follow these steps in reverse to put in place, hope that helped ya, thanks again, mr.grzz
Jan 16, 2009 | Honeywell HE260A1010 Whole House...
Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Nov 28, 2008 | Vicks V3100 1.2 Gallon Humidifier
Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
Top Essick Air Humidifiers Experts
Mack Baxter
Joseph Mueller
Joseph Mueller
Rabbit Brains
Rabbit Brains
Are you an Essick Air Humidifier Expert? Answer questions, earn points and help others
