Question about ITT Night Quest 160 Monocular
How do you install the AAA batteries in a itt night quest 160?
Cant find instruction or a drawing of how to install the AAA batteries.
3 Suggested Answers
magoo23
  • 22 Answers
SOURCE: ITT night mariner 160
My advice ,if i were you, would be to leave the batteries in for a day and leave your unit turned on. either leave the cap on, or put it in a closet and see if it works better. The new AAA batteries should be fine i'm sure you have how to put the four in correct, and yes they are all that's needed. But leaving your unit on for the day will do a few things. First, it puts a current through all of the working components, i.e. light gathering elements and your infrared components. They may "wake up" from being on and they may not. But at the very worst you are only out the cost of four triple A's.
Posted on May 06, 2008
  • 75 Answers
SOURCE: does anybody know what type of battery The ITT night quest 220 ni
I'm pretty sure that your unit uses the 3V cr123 Lithium battery. You can get it at RadioShack. You can always take it down to radioshack and pretty quick you will find the correct batt.for the unit. Do not use rechargeable batts!
Posted on Apr 22, 2009
Where is battery compartment?
{ ... ELECTRICALVoltage Requirement: 3 volts
Battery: Two (2X) AAA alkaline batteries
Battery Life: Approx. 30 hours at room temp. (the temp. will affect battery life.)
The standard military magnifying lens can be screwed onto the front object lens of the NM160 for enhanced magnification.
CAUTION: make sure to take the batteries out after operation to ensure proper storage without battery corrosion.
The only additional batteries would be if you also purchased the optional infrared light source. Otherwise there are only 2 AAA batteries.
Feb 10, 2016 | ITT Night Mariner 160 Monocular
Repairs to ITT Night Mariner 160
ITT Night Vision
7635 Plantation Road
Roanoke, VA 24019
Telephone: 540-563-0371
Fax: 540-366-9015
Toll free: 800-448-8678
General email:
nv.orderadmin@itt.com
Call For Suppliers
Warranty Repair and Technical Support Toll free: 1-800-360-6054
Fax: 540-362-7400
email: nvwarranty@itt.com
Company Links ITT
ITT Defense and Electronics
Dec 19, 2007 | ITT Night Mariner 160 Monocular
I have an/pvs-7b night vision and need to replace my battery cap. The metal piece in side broke off???
Considering many vendors who sell parts are going to have a minimum order, Night Vision Depot for example has a 100 dollar minimum; you might consider trying to repair your old one or fabricating a new one. Otherwise checking on Ebay for one. On the other hand if you can fabricate a new one easily, you might consider being a vendor of that part too as you would not be the only person to encounter that dilema.
Jan 08, 2012 | ITT Night Quest 5001 Goggles
How to reset
Hello, Just remove the batteries. Also the batteries should be alkaline batteries. Not lithium, Ni-Cd, Mercury etc. Now, I'm giving you a little trick that I learn over many years work with electronics. Take piece of wire and make sure the batteries are remove. Take piece of tape and tape one end of the wire to the positive side (+), all it will be is little shinny plate. Now take the other end of the wire and tape it to the shinny spring this the negative side(-). Rember, there are two "AA" or "AAA" batteries.
The wire goes from + of 1st battery end in the battery compartment to negative side (-) of the second battery spring (-). Rember!! NO BATTERIES, while you are doing this operation. Let the wire stay on the battery terminal in the battery compartment for 5 minutes or so. What is does if the electrolytic capacitor is holding and want drop the current which switch is turn off, it will now.
Reinstall the correct batteries then turn on your ITT Mariner 160 monocular. GB...stewbison
Feb 03, 2011 | ITT Night Mariner 160 Monocular
I need a manual for a itt vision quest 5001 or i need to know how to reset it.
Great looking product - GEN3 - much better than the Night Owl stuff from 5 yrs ago.
Not sure if you can obtain a manual for a product that is restricted by ITAR regulations. I thought these were MIL use .
The only thing I can find is a SPEC link like :-- Operators Manual. CALL US TODAY AT: Toll Free 1-800-424-8222 http://www.morovision.com/pdf/2006/ITT_NQ5001.pdf
A reset is usually any method of disconnecting the power supply for at least 3-5 secs so the sensor can discharge into ground. Just removing the batteries should do this. -- Ray
Jan 22, 2011 | ITT Night Quest 5001 Goggles
Does anybody know what type of battery The ITT night quest 220 ni
Mar 13, 2009 | ITT Night Quest 220
Itt night quest 150
Not sure if this applies, but this is on the Morovision site: http://www.morovision.com/faqs.htm Because of the manufacturing processes, all night vision image tubes will have different cosmetics such as small spots or specs, photocathode coloring, or a chicken wire effect from the microchannel plate. Most cosmetics are only noticed during viewing in high light situations such as viewing with the daylight filter on in a lit room. Most cosmetic blemishes are not noticeable during normal nighttime operation but may still be seen to some degree in certain situations. These cosmetics in no way effect the performance of the image tube and do not decrease the ability to perform nighttime tasks.
Jul 11, 2008 | ITT Night Mariner 160 Monocular
Apr 29, 2008 | ITT Night Mariner 160 Monocular
ITT Mariner 160 - How to open the case...
this unit is siliconed together to make it waterproof and outer ring on eye piece is glued on after assembley you have to pry casings apart with knife ect not easy but they do come apart without damaging internal parts make sure you also remove casing screw under label as well i have dissasembeled about four of this model succesfully
Wayne
Jan 16, 2007 | ITT Night Mariner 160 Monocular
ITT Night Quest 160 Monocular Logo
50 people viewed this question
Top ITT Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an ITT Optic Expert? Answer questions, earn points and help others
