Question about Samsung VP-W70U Camcorder
Samsung VP 500 L Help !
Hello..I own a Samsung VP 500 L video camcorder, the problem is: the unit records audio but not video, in playback mode is all ok and also the other functions are OK; what to do ?
  • 35 Answers
BAD CCD. SAMSUNG IS KNOWN FOR THIS. YOUR OLD TAPES WITH GOOD RECORDINGS PLAYBACK GOOD? YOU CAN RECORD AUDIO BUT NO VIDEO ? IT IS A BAD CCD
Posted on Jul 31, 2009
Fast tape playback for samsung vp-l770 can't watch at normal speed on camcorder?
Tapes recorded on one camcorder very rarely play back satisfactorily on another machine - you will have to use your old camcorder to view them, or else get them transferred to DVD
Oct 07, 2016 | Samsung VP-L770 Hi-8 Analog Camcorder
Recording very snowy and blurred.
If recordings are only blurry and snowy on playback on camcorder, but are OK on a different camcorder or on computer, then the problem is a dirty magnetic head. Use a mini-dv head cleaner tape. If recordings are blurred even on pc or on a different camera, then there is a fault. Faulty CCD sensor, faulty digital board, problem with internal ribbon connector, and dirty or defective lens assembly can cause this kind of problem.
Jun 16, 2009 | Samsung VP-D103i Mini DV Digital Camcorder
No sound on my samsung
if you put a old tape in that has sound in it and it does not playback sound then your internal speaker is bad. easy fix and not to much.
Mar 12, 2009 | Samsung VP-D80 Mini DV Digital Camcorder
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Samsung VP-D31 Mini DV Digital Camcorder recording black screen
I have a brand new VP-D31. It still has the protector on the screen. I acquired this (legally!) but it has no charger,cables, battery or any etcs. I got it from the Police Auctions and was too ignorant to understand what I was getting. The item was obviously stolen from a store shelf - hence no bits. How about you buy it from me?
Oct 18, 2008 | Samsung VP-D31 Mini DV Digital Camcorder
Disc playback
are u sure about the media type tat is supported in ur cam.
Jun 16, 2008 | Samsung VP-DC161 DVD Camcorder
Camcorder wont playback
SOUNDS LIKE YOUR CASSTEE COMPARTMENT IS BAD.. TRY CLEANER CASSTEE.. MAYBE THIS WILL PROLONG THE AFFECT. LET ME NO IF THIS HELPS
Feb 28, 2008 | Video Cameras
I cant get any video playback via LCD or via TV?
Hello Meerdorf, please buy the cleaning cassete for Mini DV and try to clean the head and tape path. Best regards, Arpad
Dec 22, 2006 | Samsung VP-D20 Mini DV Digital Camcorder
Playback on TV.
our television must be equipped with a/v inputs. 1. Using the A/V cable provided, connect the proper end to the a/v input jack on your camcorder. 2. Connect the other end to the A/V Inputs on your television. 3. You must tune your television to the proper source / video mode. (Consult television User Manual or manufacturer for further support) Helpful hint: To tune to video mode using the television remote, look for a button labeled: TV/Video Source Input or press 00
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Samsung VP-W70U Camcorder Logo
128 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
