Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson xp305 won't start up right
Keeps says paper jam but no paper in it
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
doc_delphi
  • 11 Answers
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
SOURCE: My Epson LQ-590/LQ-2090 keeps having paper jams
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Posted on Jun 24, 2009
  • 63 Answers
SOURCE: paper feeding, paper keeps jamming mainly on right
There is some obstruction on teh right side OR you have worn nip rollers on the spindles OR a tooth missing from a gear on one of the spindles.
Posted on Aug 14, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
My brand new 800xp won't do anything just says jammed paper & I just plugged it in
I suggest you return it to the shop and ask for a replacement printer as it is covered by warranty. Do not try to fix it because you most likely will void your warranty.
Dec 05, 2012 | Epson Artisan 800 All-In-One InkJet...
Paper jam light keeps flashing, but no paper jam can be seen. Won't print .`
Open your printer paper feeder. Then look inside it. There is plastic roll inside it. That is the curlprite. Try to open it. at the last stage you may see a spring that usually is in the plustic rollar's holle. Remove it and re assemble carefully. That's ok.
I think you will be relive from your printer problem.
Thank you.
Jun 15, 2011 | Epson Stylus CX7400 AllinOne InkJet...
Paper block button keeps on but there is no jam
Title: Paper Block on Printer
Ok one icon will be shown on your Start Bar Right corner as printer Icon.
Right Click on it and page will be shown which are given by you for print.
Clear it. And give newly for printing.
Otherwise you uninstall your driver and install it.
May 07, 2011 | Epson Printer
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
13 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
