Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG TROMM WM227HW OE error Tub wont spin
My LG Tromm WM2277HW front load washer will cycle but when it gets to the spin part of the cycle it stops and gives the error of OE. Clothes soaked water in tub won't drain.
  • 10 Answers
SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Posted on Feb 12, 2008
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
onthejob5130
  • 640 Answers
SOURCE: LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: I have a LG TROMM 4.0 WM2277HW
Normal 0 Thanks to other info gathered from this site and a few quality hours with the washer, I solved this problem for myself.
I experienced exactly the same problem. Did the same things. OE error Drain pump would not drain. Sounded like it was grinding a bit. Just not draining. Checked the strainer. Nothing. I found this link to the service repair manual which has easy to follow instructions on how to disassemble the washer and get to the pump. Removing the door and the pumps is really not that hard.
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Don't be scared. I'm a novice and it was easy. Wear gloves. Lots of sharp edges. All you really need is a screwdriver and pliers to remove hose clamps.
Anyway, I got the the top cover off, removed the front door panel section and could easily access the drain pump. I first pulled off all the hoses. All clear. Disconnected the pumps (easy once I figured out the clip the pump unit slides into). Note there are 2 pumps - a circulation pump and drain pump (larger one). All clear. Reassembled. Still nothing.
Ran a few loads of wash manually draining after each cycle (to keep the wife happy with clean laundry). Yes, you can do laundry while waiting on the part to be delivered. Just get a bucket and drain the washer after each cycle - easier if you pull off the main drain hose and drain it that way versus the little emergency drain slow (slow!).
Became convinced it must be the drain pump so I ordered a new one for $50 here. repairclinic.com
Installed new pump and reassembled machine in about 20 minutes. Worked great. NOW HERE IS SOME ADVICE THAT MIGHT SAVE YOU THE $50 for a PUMP:
After replacing the pump, I was banging on the old one to see why the heck it stopped working. During the process, I figured out how to actually pull the pump apart. There is a rubber washer around the housing below the blade - pull on it hard enough and the pump slides apart. When it did - holy cow! It was filled with grimy sandy muck. I cleaned it all out, but did not feel like testing it to see if worked. So I likely have a spare should the new one ever go out.
Hope this helps.
Good luck.
Posted on Mar 10, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Spinning cycle
Mar 23, 2008 | LG WM-2277HW Front Load Washer
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
I have a tromm washer (model wm2277hw) that sometimes will drain and sometimes not. when it doesn't i get error message OE. all connections seem to be good. when it doesn't drain there is no noise like...
An OE error presents if the washing machine has not successfully drained the water in ten minutes. Follow this link for step by step instructions for correcting the OE error code.
The FixYa Team
Dec 27, 2010 | LG WM-2277HW Front Load Washer
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
Feb 12, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
