Question about Hammering
The amature is gone in the drill. What can i do now?
How to attach drill chuck
Check for an allen bolt. Open chuck all the way and look inside for an allen bolt some drill presse have gone to this method of attaching the chuck. Hope this helps.
Jan 10, 2014 | Drills
The tork on my drill is gone can it be fixed
You might find the gearbox module needs replacing. Think it's about 60 pound for the part alone.
Oct 06, 2012 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Sticky rubber drill handle
I would try wiping it down with some Goo Gone and see if that helps.
Aug 21, 2012 | Drills
Why has my dewalt 18 volt drill gone slow and less powerful? the batteries are fine on other tools
It sounds like the motor is going bad. You could also try to take it apart and clean and relubricate the gears and shafts whith grease.
Mar 15, 2011 | Dewalt 18 Volt Compact Drill Kit
I HAVE TWO BROKEN MAKITA lxtbhp 351 z DRILLS. i
yes it is possible but you may find both gear boxs have gone in the same place it is a common problem with this drill gear box is £66
Oct 25, 2009 | Makita Drills
Hi my drill chuck is stuck and will not retract, I think the bearings hve gone. How much will a chuck be to be replaced and repaired?
tricky question the size and the cost is important so .repair drill cost versus new drill?
new drill for me sir.
repair chuck may be good but other parts should be repaired once you are inside the drill which is going to cost more.
Aug 24, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Dec 22, 2007 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Hammering Logo
43 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
