Question about HP PhotoSmart C4280 Laser Printer
Printer will not recognize new blk ink cartridge.
After replacing the black ink in my HP c4280 printer, I am getting a message "print catridge missing or not detected" I alson noticed the black cartridge is getting caught in somethingpreventing it from moving to the left. Help!!
    Problem Solver:
  • 5 Answers
1) Please do not use RE-FILLED cartridges as they will clog the heads terribly.
2) Turn off printer, Remove all cartridges, Gently move the printer head to the RIGHT with short thrusts. It is not necessary to move it completely to the right hand home position just simply away from the obvious jam.
3) With a flashlight and tweezers try to locate paper jam in the print head track. Best to also blow out paper chafe with a weak air bulb. WARNING: Do not let your male friend or relative use extremely strong air pump for tires or air blower at corner gasoline station. (Do not purchase the cheapest paper the future)
4) Unplug the printer to allow it to completely re-initialize the internal electronics..... about 10 minutes should be fine.
5) Replace all cartridges.
6) Power up printer, then re-boot your computer with the activated printer connected, then print a test page. Everything should be fine.
Posted on May 17, 2009
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
HP C4280 printer always prints with a shadowed letters, especially with the black ink. i think it started when i was installing a new cartridge and i didn't insert it at the correct angle, so i may have...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 08, 2010 | HP Photosmart C4280 Aio Printer
HP Photosmart displays a message saying "Printer Cartridge(s) missing or not detected" though I've just put a new cartridge into the machine. How do I fix this so I can print again?
Remove the cartridge.
Make sure that you removed a piece of clear plastic tape that covers the ink-jets. It's placed there to prevent the ink from drying-out while the cartridge has been sitting on the shelf at the computer store.
Re-insert the cartridge, and be sure that it "clicks" into place.
Apr 02, 2010 | HP Photosmart C4280 Aio Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
HP C4280 Printer and Ink Usage
to get the most eocnomic printer settings: go to the printer properties through control panel, adjust the print quality.
Feb 03, 2010 | HP PhotoSmart C4280 Laser Printer
Hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Nov 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
My HP C4280 won't recognize the ink cartridge.
Are you using aftermarket of refilled cartridges? The electronic chip may be damaged so that the printer cannot sense the cartridge. Try using a new OEM cartridge. Chances are that the problem will go away. If it does, take the faulty cartridge back to where you got it and ask for a replacement or a refund.
Nov 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
I think either the printer's scanner(or film as some call it) and/or the carriage is faulty. The signal cable that connects the carriage to the logic board could also be a suspect. Try replacing these items one after another and the culprit will be isolated. Good luck.
Jun 03, 2009 | HP PhotoSmart C4280 Laser Printer
Cartridge not detected or missing message.
did you remove the tape from the new cartridge ?
Dec 23, 2008 | HP PhotoSmart C4280 Laser Printer
HP PhotoSmart C4280 Laser Printer Logo
340 people viewed this question
Seeker5211
Seeker5211
