Toshiba e studio 281c error code c472 - Office Equipment & Supplies
  • 20 Answers
SOURCE: toshiba e-studio error code
It is abnormal temperature in the fuser*, thermistor error.
Maybe replacing fuser would help. But better contact service person.
*fuser, the part of a laser printer that melts the toner onto the medium. It consists of a hot roller and a back-up roller.
Posted on Feb 13, 2008
SOURCE: Error code in E studio 150
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
Posted on Feb 20, 2008
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
chad7houston
  • 62 Answers
SOURCE: Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Posted on Oct 07, 2008
  • 628 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
What can i do for toshiba 281c is giving me error code c010?
I don't think that's a valid code. Perhaps CD010? In which case there's a problem with the cleaning brushes.
Apr 06, 2015 | Toshiba E-studio 281c Copier
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
How do i check the ink/toner levels of Toshiba Studio 281c Printer/Copier
You will need the official software from the toshiba support site install it and it will show you toner levels
Jan 23, 2015 | Toshiba E-studio 281c Copier
How do I check Ink/Toner levels on Toshiba e-Studio 281c
Windows driver
my Toshiba studio 281c printer operates normally while running on windows xp through my LAN. When I try to print on it while running on windows 7, it will not respond, it does appear in the printer list?
Nov 08, 2013 | Toshiba E-studio 281c Copier
Replace heater lamp toshiba 281c
open side cover remove fuser kit and replace heat roll OR heat lamp
Nov 24, 2012 | Toshiba E-studio 281c Copier
Error c472
[C471/472/473/474/475] indicates IH power voltage abnormality or IH initial abnormality
Clear the status counter (08-400) to "0". If still occur again, u need to check followings:
1. Check the AC input voltage
2. Check the thermostat
3. Check the IH control board
- Check if the AC input connector on the IH control board, the LGC I/F connectors CN455 is dis-connected?
- Check if the fuse on the IH control board has blown.
- Replace the IH control board.
4. Check the LGC board
Jun 17, 2012 | Toshiba COPIERS E-STUDIO 520 Copier
Toshiba e-Studio 281C ADF not working
Make sure the ADF connector is plugged...
Feb 24, 2012 | Toshiba E-studio 281c Copier
Toshiba colour photocopier jamming when copying or printing in colour. error code cee0. O k in black
"CEEO" indicates Transfer belt position detection abnormality.
U need to service the transfer belt unit, especially the reflection tape and sensors.
Apr 01, 2011 | Toshiba E-studio 281c Copier
57 people viewed this question
k24674
