Question about RoadPro CAP-003PM/BK Premium Black Leather-Like Expandable Briefcase
Cap-003pm/bk road pro expandable briefcase
How to set combination
How can i open my old samsonite briefcase combination unknown
1. Pull the sliding side latch to the side,
as you would if you were opening the briefcase normally. Holding the latch in position, lightly roll your fingers
down over each numbered wheel to identify which one is the tightest. The tightest wheel will give the least when
you gently tug on it with your fingertip.
2. Set the tightest wheel to "0." Check the tightness of the other two wheels; if they still feel loose, click the zeroed lock to "1" and feel the other two wheels again. Keep going in this fashion until one of the other two wheels feels tight. When one of the other wheels becomes tight, the first wheel is set at the correct number.
3. Move on to the second tightened wheel, continuing to hold the side latch in place. Set it at "0" and check the final loose wheel. Keep adjusting the second wheel, as you did with the first until the third wheel feels tight.
4. Set the final wheel at "0" and adjust it until the briefcase's top latches pop open. Make sure the sliding side latch is still being held in place.
5. Reset the combination to numbers you'll remember in the future. Write them down and store them in a safe place, just in case.
Jan 06, 2017 | Luggage & Travel
Where can I get briefcase combination lock?
Look for my tip on unlocking luggage with combination locks.
Mar 26, 2015 | Delsey PARIS Hard Side Briefcase Business...
Fix my briefcase combination lock
Use Combination To Release Button--Factory is 00
Feb 27, 2015 | Luggage & Travel
Set combination lock
Step 1:
Locate the reset button, usually placed to the side of the combination dials.
Step 2:
Press the reset button and hold it while rotating the number dials to the desired combination.
Step 3:
Release the reset button after you set the numbers to the new combination.
Try that :)
Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
Is there an owner's manual available on line for a Stebco Attache Case Model P-16? I need to know how to set the combinations on the dial lock system.
I couldn't find the manual for your particular briefcase, but please read the instructions on the attached link. It should help you since most briefcase combination locks work the same. Hope it helps.
How to Change the Lock Combination on Briefcase
Oct 27, 2014 | Lands Phones
Setting combination u s luggage briefcase
You have this posted in the wrong product category.
Jun 07, 2012 | Cars & Trucks
I need to reset my combination on a pilot leather case
This is how you generally change the combo on a briefcase
1. With the briefcase closed put int the combination
2. Slide the bottons in the opposite direction than you usally do to open it.
3. Now set your new password.
4. Slide the buttons back into place.
5. If it dosent work the first time try it a few times
6. If it fails try reposting with more specific model information about your briefcase
Jun 28, 2011 | Office Equipment & Supplies
How do you set your own combination for the locks on the briefcase,there were no instructions with the case
  • 1 Turn the lock to the correct combination and open the briefcase.
  • 2 Look at the lock. There should be one or two pins that you can slide with your fingers. If there is one, simply push it in. If there are two, push them together. It may be the same button you use to open the case.
  • 3 Change the lock to an easy-to-remember value, such as 000 or 123, to test the lock. Release the pin.
  • 4 Close the briefcase and turn the lock to another value. It should not open. Now turn it to the test combination. It should open right up.
  • 5 Repeat Steps 2 and 3, but this time choose a number that will be easy for you to remember, but hard for someone else to guess. Write down your new combination and keep it somewhere safe.
  • Dec 29, 2010 | Office Equipment & Supplies
    I need to put a new combination on my briefcase. It has one combination in the middle
    When you open the briefcase on the inside to the right of where the combination is in the center there is a metal lever sticking out.
    Push this lever to the left and hold it there while you change the combination numbers.
    When you let the lever spring back to it's normal position, the numbers set will be the new combination.
    Jan 18, 2010 | Samsonite Tripod
    RoadPro CAP-003PM/BK Premium Black Leather-Like Expandable Briefcase Logo
    27 people viewed this question
    Top RoadPro Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a RoadPro Office Equipment and Supply Expert? Answer questions, earn points and help others
