Question about Lands Phones
Beocom 1401 doesn't ring - Lands Phones
How to change the battery of Beocom 5 handset?
contact Beocom it might have to be sent to them to change out
Dec 10, 2017 | Lands Phones
Opening a beocom 2 table charger
There could be a screw hidden under the sticker.
Aug 19, 2016 | Bang & Olufsen Olufsen BeoCom 2 Table...
Hi I'm working on a 1401 Hobart mixer anybody can please tell me how to take off the planetary unit thank you so much
A picture for this on would help but you will either have a spring pin that needs to be popped out or you will have a snap ring that needs come off. The snap ring will require a pliers made for that to get it off easy.
Nov 13, 2013 | Food Mixers
Beocom 6000 line busy
BeoCom 6000 is a cordless system phone with advanced features and elegant design
May 19, 2012 | Office Equipment & Supplies
How do I replace the battery on my Bang and Olfsun BeoCom 2 hand set
The battery retaining clip assembly sits inside a groove that holds it in place. Do not try to pry it you'll probably break it into many pieces. Using a retaining spring pliers, insert the pliers two prongs into the two tooling holes in the assembly and squeeze it so the clip assembly clears the groove ledge. It will come out slowly. Replace the battery. Assembly is the reverse.
Nov 22, 2011 | Bang Olufsen Bang Olufsen BeoCom 2 24 GHz...
Have a mazda 6 GS 2010. When I use the starter in the street, I have no problem. When I park in my drive-way and use the starter, it rings. Why?
I cannot tell you why the factory alarm is triggering at one place and not the other but I can tell you that the remote starter is not disarming the factory alarm.
In order to disarm the factory alarm, the remote starter must supply a ground pulse to the disarm wire at the body control module (BCM). The BCM is located in the driver side kick panel and the wire is black in pin "L." To arm the factory alarm, the same wire needs a ground pulse through a 1k ohm resistor.
I have not installed the 1401, so I am not sure if that particular unit has outputs for factory arm and disarm, most DEI products do have at least a disarm wire that is light green/black. This wire outputs a negative pulse that should disarm the alarm without the addition of relays. If 1401 is equipped with a alarm rearm wire it would most likely be green/white. This wire also outputs a negative pulse but it will not be sufficient in rearming through a 1k ohm resistor without a relay. The relay terminal would be wired as follows if the 1401 is capable of this feature:
30 = vehicle black wire (solder in 1k ohm resistor)
87 = chassis ground
87a = no connection
85 = green/white wire of 1401
86 = 12v constant (fused - 5A is more than enough)
Nov 09, 2010 | 1401 Remote Start/Keyless Entry System
My Beocom 6000 table base unit no longer charges
If your base has a charge indicator on it and it indicates that the handset is charging when the handset is in the cradle, I would say you need a new battery. RadioShack sells a replacement battery for $22.00 at the following link
http://www.radioshack.com/product/index.jsp?productId=2815547&CAWELAID=107599274
If the charge indicator doesn't come on it is unlikely that it is the battery. You may be able to get the phone repaired by the manufacturer but it may be better and more practical to get a new phone.
Jan 07, 2010 | Lands Phones
Problem with B&O beocom 6000 ''extension'' no contact with base
I think you just need to re-register the phone to the base. Press the button on the base station (between the 2 charger pins) then go to the handset setup menu, scroll to register handset.
Feb 25, 2009 | Lands Phones
Lands Phones Logo
44 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
