Question about Kenmore 76081 Wall/Window Air Conditioner
Can this model be used in a existing thru the wall opening
Can the kenmore a/c model 76081 be used in an existing thru the wall opening
  • 148 Answers
As long as it is large enough if not you may have to cut the hole a little larger but yes you can use it
Posted on May 17, 2009
Window air conditoner runs constantly
the termostat is broken . you need to change it
Jun 29, 2012 | Kenmore 76081 Wall/Window Air Conditioner
With a Kenmore 8000 BTU ac window unit there is a green wire that runs from underneath the control panel. Where does that go?
Most of the time a green wire is a ground and should be attached to the metal frame using a existing screw or a self tapping sheet metal screw. Thank you.
Aug 26, 2011 | Kenmore 75080 Thru-Wall/Window Air...
I can't find one this model replaced model 74054 purchased in 6/10/93 thank you
Your message was a little confusing. But, if you're looking for the Kenmore 75050 Thru-Wall/Window AC, you can find it at Sears online at the following link.
http://www.sears.com/shc/s/p_10153_12605_04275050000P?keyword=kenmore+75050+thru-wall%2Fwindow+air+conditioner&sLevel=0&prop17=Kenmore%2075050%20Thru-Wall/Window%20Air%20Conditioner
Hope this helped you find the model you wanted. Please let me know. Thanks.
Jun 09, 2011 | Kenmore 75050 Wall/Window Air Conditioner
Kenmore 12000 btu turns on fine but after a few minutes fans shut off and compressor keeps running this is a heat and air model
First replace fan capacitor and try, if not, bearings worn out in your fan motor. Replace bearings or motor with new capacitor.
Jan 14, 2011 | Kenmore 76081 Wall/Window Air Conditioner
Finding a suitable thru the wall air conditioner
Not exactly....if you can half or more of the side vent exsposed then you will be okay...I like the side vent models because they are less prone to recycling the air...they either pull in the side and expell out the back or visa versa...
On the total back models all the air is just pulling and pushed out the back and they are prone to overheating in some wind conditions...the air just recycles...
Of course the main problem is that most people fail to keep their unit cleaned properly and that causes the overheating...
Window Air Conditioners - Clean them every year
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
heatman101
Jul 20, 2010 | Kenmore Heating & Cooling
The fan does not work on high speed
1)Sometimes fan motors will 'lose' a speed.
2) the switch could be 'wired' incorrectly and 'Hi Speed' is not connected.
3) the switch itself could be bad
good luck!
May 03, 2010 | Kenmore 76081 Wall/Window Air Conditioner
Bad vibration and noise suddenly in a 5 month old air conditioner
please make sure this vibration not from the unit fixation if ok check the fan may be brockenor blower
Sep 16, 2009 | Kenmore 76081 Wall/Window Air Conditioner
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Water is shooting out the front
Your angle for the unit needs to be pitched away from the house by about 5 degrees. If it is level or leaning towards the house water will drain into the living space.
Mar 13, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Kenmore 76081 Wall/Window Air Conditioner Logo
111 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
