Question about Craftsman Garden
Can't figure out how to put on new string after i took off the old string
I took apart my craftsman electric weedeater to replace the string and now i don't know how to load the new string I bought. I am not machanically inclined - need basic instructions. Thanks!
I figured it out. Went on YouTube and watched a couple videos and did it myself. Thanks!
Posted on May 18, 2009
How do i remove the head to replace the string on a Murray M2500 trimmer?
How do i remove the hend of the weedeater it is stuck on there. I believe it is stripped
Sep 08, 2014 | Garden
Need parts for American Gardner Yardstick model YS24. Specificly the line head assembly.
How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
Sep 01, 2013 | Weedeater Garden
How do I take apart craftman 25cc gas weedeater to replace the string?
Same problem here......need to replace the trimmer string......some of you guys and probably some ladies know this...Ple Don't know which way to turn the head to get it off, or if I also need a tool to remove it. Please help!
Aug 21, 2011 | Craftsman 25cc Gas Line Trimmer
Only runs on choke
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
Jan 10, 2018 | Craftsman 25cc Gas Line Trimmer
Don't know how to advance cutting wire.
Did you try bumping the head on the ground? Also, the head could be dirty, keeping the string from feeding. Or maybe the previous owner tried putting a larger size string in the head. Check to see what the proper size is for your trimmer.
Both of these suggestions could cause this.
Jim
Jun 03, 2009 | Craftsman Garden
Garden Logo
495 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
