Question about Samsung DVD-R155
DVD player will not read disk
Will not read disk
When i burn a disk on dvd,it will not play on my dvd player?
Some DVD-players only read 'DVD-R' disks.
Some DVD-players only read 'DVD+R' disks.
Be sure that the "blank" disks you are using are compatible with your DVD-player.
Sep 22, 2010 | Dell Inspiron 530s Desktop Computer...
Incert dvd read out sats NO
Hello
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
BEST OF LUCK
Jul 13, 2010 | Toshiba SD-K760 DVD Player
Reads, NO DISK
Curtis DVD player does not supports the file type.
May 28, 2010 | Curtis DVD1045 DVD Player
Program says dvd+r incompatible with toshiba dvd player
Some DVD players will read 'DVD-R' ("minus-R") disks.
Some DVD players will read 'DVD+R' ("minus+R") disks.
Some DVD players will read "both" types of disks.
So, if you're burning onto a DVD+R disk, you won't be able to "play" the disk on your Toshiba DVD-player.
Instead, buy "blank" DVD-R disks, and write on them.
Apr 05, 2010 | Computers & Internet
Suddenly my DVD player is saying "no disc" after trying to load DVD. Why isn't it sensing the DVD has been loaded?
When a DVD goes into DVD player it has to spin it and read it. If your DVD player is not reading the disk. The disk could be dirty. The DVD player might need to be cleaned. You could be trying to play a PAL disk on a NTSC player or Visa Versa. or the region coding might be wrong. Try playing a clean disk that you have played in it before. That might tell you if you need to clean the DVD player.
Mar 03, 2010 | GoVideo DV2130 DVD Player/VCR
Error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
Why does it read bad disk? i've tried two disks, that work perfectly on another DVD player. But reads as Bad disk on the GPX D2816
its the disk laser sensor is to sensetive that why it canot reads with an ordinary disk or a pirated disk or a disk that has a small scratch.
Nov 07, 2009 | GPX D2816 DVD Player
The dvd player is not reading disk
is it a burned disk?.
some dvd players can read a disk You burned/made but only if the DVD player has AVI or DIVX logo on it.otherwise they Will Not play a burned movie/DVD..
Aug 12, 2009 | Samsung DVD-P230 DVD Player
Does not read disk
My portable dvd player turns on and the disk does not spins but the screen turn light blue and does not read the disk
Aug 03, 2008 | Liquid Video MVBG45 Portable DVD Player
Samsung DVD-R155 Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
