Question about Sharper Image Literati Reader 16375680042 Tablet PC
Samsung galaxy note 10.1 2014 edition won't turn on
New today, the 'notebook screen' opens and shuts periodically.
How can I reset my Galaxy tab 2 7 to its original settings?
Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ... Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
Jun 18, 2014
How to Hard Reset the Galaxy Tab 3 - Android Forum ...
May 7, 2014
More results from www.androidpit.com
Galaxy Note 5: How to Perform Soft & Hard Reset
www.technipages.com/galaxy-note-5-how-to-reset
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
Dec 21, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
How do I turn my Samsung galaxy 10.1 2014 edition tablet on
hi,
to turn your
Samsung galaxy 10.1 2014 edition tablet on you need to long press the power button which is at the top-right side of the tablet.Hope youo get your problem fixed. Thanx
Feb 11, 2015 | Samsung Galaxy Tab 101 Tablet...
Samsung galaxy note 10.1 edition make emergency calls
Your sim card or network is not recognised or detected. Make sure that you can see your network displayed on your tablet. If no sim card or network is detected by your phone or tablet, you can only make emergency calls
Apr 24, 2014 | Samsung Galaxy Note 10.1 Tablet - 2014...
New Samsung Galaxy Note 10.0 battery life and charging time
Sounds normal to me!!
The further away from wifi router you are the more power is needed by the wifi card.... etc etc so the 8 hours is in perfect conditions with the screen brightness at minimum and no apps running!! It's safe to say that, whatever battery life is quoted for any device you should only expect to acheive half that in the real world.
The screen is prob responsible for 80% of the battery's power drain. Turn the brightness down. Stay in same room as router. close down un-used apps that demand cpu and network (wifi card) time.
Shut it down completely when charging don't just let slip into standby. Also don't charge it on a cold or hot place such as a window sil. To high or low tempretures will increase charge time and will damage the battery lowering it's capacity.
May 30, 2013 | Samsung Galaxy Note 10.1
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Samsung tablet 7.0 will not turn on
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
Sep 13, 2012 | Samsung Galaxy Tab Tablet PC
Sharper Image Literati Reader 16375680042 Tablet PC Logo
16 people viewed this question
Top Sharper Image Tablets & eReaders Experts
Robert Karst
Robert Karst
Ivan
Are you a Sharper Image Tablet and eReader Expert? Answer questions, earn points and help others
