Question about Sony Playstation 3 (PS3) Console
Panasonic viera TH-L32B6Z TV
Hi I am connested PS3 to the TV and the audio for the games wont work either through the HDMI of the component. Works on other TV's fine. Can you advise a solution. Cheers Wayne
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
SOURCE: PS3 HDMI Audio Problem
The settings on your PS3 may be to high for your TV. try turning off your PS3 and turning it back on, when you turn it on hold the power button untill it beeps aprox 10 sec. this will reset the your PS3 back to original (minimum settings)
Posted on Nov 23, 2008
  • 7 Answers
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Posted on Jul 06, 2009
SOURCE: PS3 not working thru HDMI cable
i am having the same problem, so i called the mfg. of the tv and they told me to set the PlayStation to out put 1080i and not 1080p i don't think this is possible. my tv is a Hitachi and they are sending me an update card for the tv, hopefully this will fix the problem. Apparently its a problem with the tv not being able to receive a 1080p signal
Posted on Oct 31, 2009
  • 149 Answers
SOURCE: PS3 wont work with AJAX after using HDMI cable
ps3 does not reset the video automaticly you have to reset it yourself any time you go from one mode to the other
to do the vid reset just hold the power button when in standby(red light) untill you hear second beep then release
Posted on Nov 05, 2009
Panasonic viera th-42pc77u both hdmi connections have stopped working. should i replace the entire board or??
hi i'd try a factory reset before you buy any boards, to do this press and hold volume down button and then press info on the remote control 3 times, when your in the service menu select reset this will restore the tv back to when you brought it hope it helps
regards
shaun
Jan 17, 2014 | Panasonic TH-42PC77U TV
I'm trying to plug my ps-3 to my panasonic viera th-50pz80u with an AV multi-out but i have no signal. No sounds, no images. Please help me
In your PS3 configuration you'll likely have to set the PS3 so that it is using the multi-AV rather than HDMI.(In Video Output Settings) Also on the TV input you'll have to select composite in rather than HDMI.
https://support.us.playstation.com/app/answers/detail/a_id/788
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Hope this helps,
Jeff
Nov 03, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
The hdmi ports (2) do not work on this tv....how do i correct. I have connected 2 different blu ray players and a sony ps3.....the players would play audio but no sound. the ps3 - nada...
Tries tv unplug replug it back like an hour later for a tv resetting itself.The HDMI (2) port might be working again.Just used the PS3 game system only conennected it in the different tv ports of for the HDMIS ports provided by the tv.U know this wright?The PS3 game system play all this funsctions.CD-Audio only,DVD movies and old PS1 games,some PS3 system may,may not support and play old PS2 games,All Blu Ray movies and All PS3 Blu Ray games.
May 13, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Linking up Plasma,PS3, and Receiver
If your tv and reciever have optical audio (square-ish hole with a red light), that would be the easiest way. Just get an optical audio cable and plug it into the optical out on the tv and into the optical in on the Sony.
Dec 30, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
