Question about Building Materials
How to untangle garage door opener cables - Building Materials
3 Suggested Answers
  • 3197 Answers
SOURCE: garage door opener model 139.53615sr. can i
You can buy the chain and cable assembly at any good door opener service company. I doubt you will find aftermarket though.
Posted on Nov 30, 2009
Testimonial: "very helpful, thank you"
Mechanic395
  • 39 Answers
SOURCE: i had to use the emergency cable to open garage
This usually works:
  1. Close the garage door from the inside, you should be in the garage ;-)
  2. Just pull the cable back, towards the motor until the latch clicks in place. You may need a ladder, and it may not make much of a click, but you can usually do this from the ground.
  3. Now operate the motor and you'll see the shuttle travel towards the latch and connect with a click.
  4. Open the door!
Posted on Jan 18, 2011
Testimonial: "You are awesome! Seriously! Your quick reply was the best thing that happened to me today. Ice, snow, no power...your answer worked and made my day!"
Craftsman 1/2 hp garage door opener cables wound around shaft
Denise, This could be a dangerous job for some one with no knowledge, doors are heavy,cable is under a lot of load from torsion springs. You may have to call a garage door tech, this is not a major fix if you have the knowledge and tools, the Tech. can also diagnose what caused/allowed cable to do this and correct the fault, so it will not happen again. For your safety call a door Tech. or 3 and get an estimate.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jul 27, 2016 | Sears Craftsman LiftMaster Chamberlain...
Tip
Inspecting a garage door opener.
<p>Use the pull cord and disconnect the opener from the garage door. <br /> <p>Operate the opener and let the carrier slide back away from the door. <br /> <p>Is the carrier moving smoothly when disconnected?<br /> <p>Operate the opener into the down position, does it run smoothly? <br /> <p>Next, lift the door by hand from the bottom to the top. Is it moving smoothly?<br /> <p>Run the door down, ensuring that it moves smoothly. If not, lubricate the axles of all the rollers on both sides of the door.<br /> <p>Check the cable pulleys at the top sides of the door channel, lubricate them as well. <br /> <p>Are the two cables in all four of the pulley grooves?<br /> <p>Are the cables hooked properly to the bottom of the door?<br /> <p>Now, connect the opener to the door and try it.<br /> <p>After checking those things, there is an "up force" and a "down force" adjustment on the opener, try increasing the whichever is needed by by turning the adjustment in the direction of MORE force.
on Jan 09, 2011 | liftmaster Chamberlain Garage Door Opener...
Cables are loose on both sides of garage doors and garage door will not open
I think your spring is broken. You should contact your local door service company.
Aug 20, 2013 | Sears Craftsman LiftMaster Chamberlain...
I had to use the emergency cable to open garage door when power was out, how can i reconnect cable now? It is a craftsman 1/2 horsepower door opener, double door for a double garage door.
This usually works:
  4. Open the door!
Jan 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR WANT CLOSE, USING CLOSER WILL MOVE A LITTLE BUT LIGHT FLASHES, SENSORS SEEM TO BE WORKING
I recommend this to everyone with garage door opener problems:
Use the pull cord and disconnect the opener from the door.
Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected?
If not, lubricate the hubs of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well.
Are all cables in all the pulleys, there are 4.
Dec 07, 2010 | liftmaster Chamberlain Garage Door Opener...
The cable broke and I need to replace the cable. Don't know where to purchase the cable.
The chain and cable are an assembly and will be available at Sears or any good door opener service company.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener model 139.53615sr. can i
Nov 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Genie garage door motor. Whenever I try to open the garage door, the door opens about 5" and then simply stops. What's going on?
check the track for tight spot it will stop if it is not stright, too close or too wide also check cable or chain for dirt lubracate all
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor wont run on craftsman opener
You need to remove the cover and look at the drive gear. It is probably stripped. I really recommend a technician to repair your door.
May 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
161 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
