Question about Umarex Zombie Hunter Blaster
Gun not getting any bbs
Why does my gun not get any bbs when i pull the trigger when i wind it up
How do you get a stuck wooden stick out of a hot glue gun?
Switch the glue gun on and allow it to heat until the glue softens and then try and pull out the stick.
Feb 08, 2018 | Crafts & Hobbies
Need wiring diagram or schematic of the primary, secondary, and lighting windings or a weller soldering gun. even arough drawing of the windings that's close would work
You know that's a bit goofy, right? Only the manufacturer would have such information.
If you are serious, you CAN do it. Begin with an accurate Ohmmeter to measure the primary and secondary winding resistances on a new gun (at Sears, say.) To do that, measure the new gun's primary resistance at the plug with the trigger pulled, of course. Remove the gun's soldering tip and measure the resistance of the secondary without the tip and any incandescent bulb in place. (No need to pull the trigger.)
Hopefully you have some of the burned wire from the old gun. Measure the diameters of samples of the burned primary (thin) and secondary (thick) wires with a micrometer. With that information, look up wire gauge information online. You may need 24 gauge and 18 gauge enamel coated wire, for example. Note: a burned wire will no longer have its enamel coating so take that into account when determining the gauge of the "new" wire.
Note the "Ohms/foot" specification for each wire gauge. Divide that number into the resistance values you measured on the new gun (at Sears...). That will indicate the number of feet of each gauge of wire you will need to rewind the core!
Now I'm off to build my own refrigerator... NOT!
Feb 11, 2015 | Cars & Trucks
Crossman repair
I have a crossman pulse r78 and it will not shoot ,when you pull trigger it Gus windes oner spring do not egage
Dec 05, 2013 | Crosman Model 760 Pumpmaster Air Rifle
The BBs won't come.the gun won't it's a MCSR01 crosman air gun
With magazine out, what happens after cocking, should get a gush of air, if nothing, spring not latching, or seal leaking badly, have you adjusted trigger, to fine with a spring type, will not latch, so no pressure, can you feel anything happening, nothing at all spring latch, can you feel the pressure of the spring when you cook it.
Mar 15, 2013 | Optics
Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Oct 16, 2012 | Stanley Bostitch Rn461 Gun Coil Roofing...
The gun constantly exhausts air when connected to air compressor. Won't build up the pressure when connected. Must disconnect between firing trigger
Easy fix if air is leaking out the top of gun. Remove the head and lube with white grease or silicone paste. If orings seem to be loose, order repair kit from dewalt (you can tighten orings by removing the oring and wind a bit of teflon tape in the oring groove). If air is leaking from the trigger, replace the valve. If air is leaking out the bottom where the nail ejects, pull out the cylinger and lube the orings that seal the cylinder to the body of the gun.
Oct 19, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
I just purchased a SIG 552 Commando Airsoft rifle and after about 35 minutes of use, it stopped firing anything. Battery is fine, just doesn't seem to be picking up the BBs or possibly jamming, but can't...
Alright another winding mag issue. On the bottom of your mag there is a wheel, wind it until you meet resistance or you hear double clicks, this will tell you when your done. After fire a certain amount of bb's it will need to be rewound.
Jan 29, 2010 | Ics Hop Up Bucking for Airsoft Guns
Marksman 1010C repeater air pistol
sorry if you already learned but you have to **** it, and at the front under the barrel exit is a button looking shape press down on that really hard and on the top of the gun a sloped shape should appear. do not put the bb in the circle shape hole put the bbs in the top square shaped hole. push the object down and aim then pull the trigger!
Sep 08, 2008 | Sport & Outdoor - Others
Umarex Zombie Hunter Blaster Logo
809 people viewed this question
Top Umarex Hunting Experts
mark moore
mark moore
Level 1 Expert
Dan Apthorp
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Are you an Umarex Hunting Expert? Answer questions, earn points and help others
