How do I get words to pop on TV screen for coco pro gigstar ii
System will not turn on, but I can plug another device into the external ac power plug and that device turns on. What could be the problem?
The problem could be with your power adapter in which case it will be fairly easily solved. If there is another device with a similar power adapter, check that. If the power adapter is fine, then you need to call the customer service guys for your Karaoke System.
Aug 30, 2015 | Vocopro GIGSTAR-PRO-II Professional...
All ways to bypass a locked screen in panigram
If you swipe the pattern wrong 5 times Android should pop up an option to wait for a timeout with a button that says "forgot pattern". If you click on that button you should be able to type in the Google account info that the system is setup on and it should put you right in.
Mar 13, 2014 | Coco Android 2.1 Tablet (837121001186)
4 letter words from these letters b n c o a f
abba
anna
anon
boca
boff
bona
boon
coca
coco
conn
nono
noon
Nov 21, 2013 | Games
MIDI Epad hangs up at the word android will not boot all the way up
contact the manufacture or costumer service for that product and ask for service
Aug 28, 2012 | Coco Epad - -10.2 Inch Touch Screen Google...
Coco girl on facebook problem bottom of screen doesn't appear
send a msg to the ppl that are in charge of the game somewhere it should say contact us or report a prom, click on that and send them an email that will fix the problem. it has happened to me a few times and that seems to work
Aug 02, 2012 | Facebook Apps
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
WORDS WITH LETTERS A N L O F C
  • foal
  • loaf
  • can
  • fan
  • loan
Jan 10, 2011 | Games
Magnovox big screen hdtv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 13, 2008 | JVC AV-56WP74 56" Rear Projection...
Red horizontal lines won't line up.
convergence ic bad
Jan 06, 2008 | Mitsubishi WS-65809 65" Rear Projection...
 Grubhead
Grubhead
