Question about Crosman M4-177 Air Rifle
Stock broke on m4-177
The stock broke off of the gun, is there an easy way to fix or a replacement part, only 2 days old out of box, cannot find receipt, got lost with the rest of the our Christmas gift receipts.
Glove box latch
Sure it is, have confidence in yourself. Do the exact opposite you do to remove the old one when you install the new one. You'll do fine
Sep 06, 2013 | Hyundai Cars & Trucks
2 lug-nut studs sheared off rear tire. How much to replace them? and why did it happen?
GO TO TIRE CENTER OR GARAGE THAT SALE TIRES AND DO BRAKE WORK.THEY WILL HAVE TOOLS TO REMOVE BROKEN STUD AND PRESS IN NEW TIRE STUDS.REASON TIRES STUDS BROKE TOO MUCH TORQUE WAS APPLIED TO BRAKE STUDS CAUSING THEM TO BREAK.COST TO FIX ABOUT $60.00
May 25, 2011 | 2008 Ford Explorer Sport Trac
Some kind of water flow or thermostat box is broke
It is the water inlet housing. It has a pipe screwed to it that goes under the lower intake. You can unbolt the pipe and change the housing but the easiest way to do it is to remove the upper intake. I was in a carquest store the other day and they had these housings in stock.
Apr 08, 2010 | 2001 Chrysler Concorde
Window tilts forward when going up
The forward track channel has either rusted out, broken, or the sash clips to help keep the window level broke. We have seen all the above, but most likely is the sash clips that glue onto the lower window broke. The door panel will have to be removed, the old clips, heated with a HOT heat gun and removed, and new ones installed. Pretty easy fix with the right equip.
Jan 19, 2010 | 2000 Pontiac Montana
Bad air leak out of handle can it be fixed
Depends, older Vacula 010 guns were easy to fix with new o-rings on the valve (there should be 2), the newer 020 guns can leak and seem not to be repairable, even with new o-rings. Unfortunately the older guns have been out of production for 4-5 years, replacement parts are not available. But the o-rings are a common size o-ring, easily sourced.
Dec 16, 2009 | Vacula 4" Full Flow Blow Gun
Broken terminal, the possitive terminal on the sub broke. but the sub isnt blown i dont wanna buy another. and ive putten the wires together and tapin it but it wont stay and either will a wire **** i need...
you can solder a new terminal on. its realy easy actually. you can buy a pen soldering gun for like 3 bux and get flux core solder not acid flux!!! the solder is really cheap too. if you never soldered before its really easy. first twist the wires together(in your case slip the treminal end over the wire coming from your sub and if its not a wire depending on how it broke like if part of the old treminal is left you can just solder a new one to that. grab a flat blade connector the same size as the one that broke off) just let the soldering gun heat up then dab a little bit of solder onto it and touch the tip of the soldeing gun with the ddab of solder facing the part you wanna heat up hold it there and keep dabing the solder onto the parts your heating and when it melts (should take only a fue seconds) dab it till there is a good amount of solder melted on there not so its driping off but enough to surround the 2 pieces remove the soldering gun and your done!! then just plug the wire back onto your new treminal! if you kneed help or i misunderstood your question let me know and pics always help!! :) good luck
Aug 25, 2009 | Kenwood KFC-W3011 Car Subwoofer
397 Ben/Sher .177 air rifle - installing repair kit problem
Crosman bought out benjamin / sheridan, and they still repair just all their pump guns. The ring sounds like a piece of a pellet, the barrels are silver soldered to the bottom tube, Not lead. Also, the repair kit should not have too many parts, you can only go so far with those guns before needing special equipment to get them apart. Get a hold of Crosman and tell them that benjamin sent you a bad part. They should fix it.
I had an old Benjamin Franklin in .22 cal, it was just a brass tube with a stock and barrel. I sent it to them, to be repaired, and I wanted the .22, because I had the 5mm and the 177. So I got it back, cost $29, New barrel, in .177, soldered on, new guts, new paint, trigger, bolt, the works.. Brand new gun. I told them I wanted the brass and I wanted the .22, They said oops, sorry. I didn't complain, nice old gun. Hope this helps.
Jul 29, 2009 | Crosman (4032)
I had broke the front aim sight. Can I recover it?
you could contact thecompany that make this gun and ask them if there is anyway to replace the broke front aim sight
but most likley you wont be able to replace it and just have to buy a new one
Jun 24, 2009 | Crosman Phantom .177 Caliber Break Barrel...
The screen "shield" on my tv broke, i need a replacement part #
mine got broke also
i called the local tv repair shop, they had the piece in stock and it was 100.00
it was and easy replacement for me too do it myself!!!!!!!!
Jun 01, 2009 | 1992 Chevrolet Camaro
Putting back togethet my Stinger R34 Airsoft Gun.
take the gun put in in a card board box and BURN IT!!!!!!!!!!!!
Jan 25, 2009 | Crosman (4032)
Crosman M4-177 Air Rifle Logo
51 people viewed this question
Top Crosman Optics Experts
Anthony Coots
Anthony Coots
Level 1 Expert
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
