Question about Bodum Coffee Makers & Espresso Machines
Bodum drip coffee maker shuts off before finished brewing, even after it has been cleaned/scaled
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
SOURCE: Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Posted on Mar 10, 2009
VtToolMan
  • 704 Answers
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
SOURCE: our coffee maker is only brewing half of the
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Posted on Dec 16, 2009
When I brewed coffee from my Keurig mini k10 brewer, the coffee came out of the center and the side (spilling coffee into the drip pan) but the resevior was not overfilled and the coffee was not finished...
Sometimes things can build up on the inside of the machine, even though you may have only had it for a short period of time. You should try cleaning it to make sure nothing is clogged in the filters.
Oct 14, 2013 | Coffee Makers & Espresso Machines
Keurig Platinum B70 Coffee Maker not de-scaling properly?
Purge and blow out the lines. Debis is in tubes and ports.
Jan 12, 2012 | Keurig Platinum B70 Coffee Maker
Coffee drips slowly and water doesn't drain completly from filling chamber. had machine for about 6 months and was happy until today.All I hear is a humming, a slow drip of half a cup and then it shuts off...
mcdevito75 here, Your coffee maker most likely needs cleaning, Water will leave deposits in the brewings ports over time and will have to be cleaned out, Follow your owners manual on cleaning your coffee maker.
Jun 17, 2010 | Keurig B100 Coffee Maker
When i make coffee sometimes the water that comes out is cold or luke warm
The brewer has not had enough time to reach its operating temp (usually 7 mins after a brew cycle). If that is not hte case then the machine needs to be descaled.
Feb 18, 2010 | Bunn VPR Coffee Maker
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makee shuts down and won't turn back on
It's little computer may be scrambled, or its channels may be clogged with scale. You might try (1) unplugging the unit for several minutes to reset the computer; (2) descaling the unit with a vinegar solution.
Sep 27, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee maker not working
Here are some of the most common problems that can cause your drip coffee maker to stop working:
  • The power cord or on/off switch can go bad. In either of these cases, it's best to get a pro to replace it or buy a new coffee maker -- replacing it improperly can lead to a fire.
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
  • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
There are two problems that are nearly impossible to fix:
Failure of one of the heat-sensitive switches
(This is The coffee maker's temperature sensors)
Failure of the heating coil:
(This is the The coffee maker heating coil)
Because it's nearly impossible to get replacement parts, you probably have to buy a new coffee maker if one of these problems disables your machine. Now, when you make coffee tomorrow morning, you can do so with a new appreciation for exactly what's happening inside.
Goodluck,
Please don't forget to rate the solution
Apr 01, 2008 | Keurig B50 Coffee Maker
Coffee maker shuts off during brew cycle
I to have been battling this same problem on and off for a couple of years, and have been trying to find out why it thinks it id done brewing. I have had some success but exactly what fixes it I don't know.
I called Cuisinart and they told me to change the water filter in it. This didn't work, but I did see some grounds and even a bean had gotten under the filter. I cleaned that out and it fixed it, that time. If you don't have a filter, shine a light down the water reservoir and make sure you don't see anything.
Other than that I do a bunch of cleaning cycles with, Brew Rite Cleaner, Whink Automatic Drip Coffeemaker Cleaner, and vinegar. Don't mix them, just follow the directions on each. Follow with a bunch of rinse cycles. I still don't know which one does the most to fix the problem. For all I know it could just be all of the rinse cycles.
Just keep trying, there is hope that you won't have to tend to your coffee maker forever.
Nov 29, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
