Question about Health & Beauty
Cae2743bq all leds lit cannot enter service mode
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
Sep 01, 2013 | Whirlpool Washing Machines
This machine was spinning with an uneven load and stopped working so I emptied the machine and took it apart. I found the shock absorber on the tub needed to be put back together so I fixed that problem...
The error E68 means the ccu has sensed a stuck button on the console. MANY times this is a false error and means that either the ccu or interface must be replaced, but SOMETIMES, there really is a stuck button. TRy to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound
1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,
the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle
back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the
display showing moisture sensor readings. Opening the door (press in on door switch plunger) and placing
a finger on the both moisture sense bars at the same time will make the numbers decrease. In controls that
do not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switch
plunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LED
come on.
4 turns: Drive motor runs; heat source is off.
Key test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power
from dryer. Dryer will be reset for regular operation.
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the intrface OR ccu, but in my experience, it's usualy the interface that ends up needing replacement. Here is the part to order.
Nov 10, 2012 | Frigidaire Affinity ATF8000FS
E68 error code
This E68 is a stuck keypad.
The error E68 means the CCU has sensed a stuck button on the console. MANY times this is a false error and means that either the CCU or interface must be replaced, but SOMETIMES, there really is a stuck button. Try to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1 time and " res" will be shown briefly in the display.
come on.
Key test:
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the interface OR CCU, but in my experience, it's usually the interface that ends up needing replacement. Here is a link to the interface board.
Oct 15, 2012 | Frigidaire Affinity ATF7000ES Front Load...
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
The locked light is on but I am able to open the lid. It will not start
Hello barbarafreel,
Your machine type is a FAV6800A correct? If so I would try to recycle 120VAC power to the machine. Pull the washer power cord for 30 seconds then repower backup. Do you still have the Lid Lock LED lit? If so further trouble shooting is required. I would next have you go into Service Mode. Once in Service Mode we need to go Board Output Test on page 16 of the Service Manual I will summarize below.
Here is the FAV6800A/FAV9800A Service Manual for your machine. Follow all safety warnings when working on the machine.
Let’s see if you can get into Service Mode, from the Service Manual slightly modified;
Enter Service Mode by pressing and holding the Enviro Plus and Spin Only keys simultaneously for three seconds or the display reads “00”
Now look at page 16 of the service manual let’s see if you can with the Board Output Test function unlock and lock the Left and Right Lid Locks.
Now press the Delicates key.
The LED display should show ot and the Quick Wash led will be lit.
The Left and Right Lid Locks will lock.
Now press the Extra Rinse key pad.
A few seconds should elapse and the Whites led will go lit for a short duration then off and in a few seconds the Lid Locks should unlock. Do the Lid Locks unlock?
Now press the Colors / Jeans key pad again.
Do the Lid Locks lock?
Let me know what action took place and we will go from there.
You can get out of Service Mode by pressing Enviro Plus and Spin Only keys simultaneously or press the Off key.
What I suspect is one of the lid lock is not releasing completely which moves a slide switch in the lid lock to signal the control board that the Lid is Unlocked and the Lid is Locked.
If you still have the issue I would release the washer top form the base and unplug the Right Lid Lock and see if that right lid lock is signaling incorrectly and possibly causing the issue. The Service Manual will show you how to release the washer top from the base. The left lid lock because of its dual signaling function “the Lid is Open/the Lid is Closed” and “the Lid is Locked/the Lid is Unlocked” can’t simply be unplugged. If you pull the Left Hand Lid Lock plug you will show a OP or OD error from the Control Board. If you are up for the troubleshooting I will help you proceed further.
Only the Left Lid Lock assembly needs to be plugged in for the washer to work as designed. I removed my Right Lid Lock a year ago and would never spend the money to replace it my choice.
Dec 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The signal keeps beeping constantly, how can I stop this?
If it’s a FAV6800AW or FAV9800 are there any codes in the console display? Have you tried to recycle power to the machine? If you haven’t already done so disconnect the 120VAC power plug on the machine and reconnect after 10 seconds this is a hard reset to the machine Control Board. Does it still beep when you try to start a cycle?
Lets see if we can get into the machines Service Mode.
This is from the FAV6800AW/FAV9800AW Service Manual board output test on page 16.
Enter Service mode;
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys simultaneously for three seconds or until the control beeps. The Console display will show “00”.
Access Board Output Test by pressing the Delicates key. The console display will show “ot”
The lid lock will lock and the Quick Wash LED will be lit. Will the machine allow you into Service Mode?
If not have you recent storm activity in your area and do you have surge protection on the 120VAC outlet powering the washer?
Report back and we will go from there. Rich
Jul 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I got LED lit on but black screen. No harddrive movement or sound
when you power up the computer press F8 key if you can see safe mode and otehr menu then you can do it.
Enter in enable vga mode then change screen resolution 1024*768
Jul 27, 2009 | Acer Aspire 5920-6727 Notebook
Canon pixma mp145
mas saya mau download canon pixma mp145 ko susah banget ci please saya lagi butuh banget..!
Oct 31, 2008 | Canon PIXMA MP150 All-In-One InkJet...
How to reset wasted ink counter
Mp150
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Nov 22, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Health & Beauty Logo
113 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
