Question about VIDAR Systems Select P42
Select P42 Plus
I get stiching errors and no movement in camera position during vertical camera alignment .  I can't even finish a calabration.  What to do.
I have also got the same problem. If u got any solution then please share it with me. my mail id is ranjeet29330@yahoo.co.in
Posted on May 11, 2011
Why are my photos blurry?
There are only three reasons photos look blurry: poor focus, shaking the cameral during the shot, or trying to take a photo of a fast-moving subject with a slow-speed camera.
You can usually see focus problems on the display before you take the picture, so that doesn't appear to be your issue. On the other hand, movement of camera or subject happens during the shot, so you'll only see that in the completed photo.
Camera movement first. Many cameras today have built-in "anti-shake" circuits that sense when you're the problem -- you're moving the camera during the shot. The best ones are very good at eliminating shakiness, but even they can't overcome large movement, as when you mash down the button to take the picture. If yours doesn't have anti-shake, or it isn't very well implemented, you'll just have to practice pushing gently on the button and holding the camera very still until it finishes the shot.
As for subject movement -- well, more sophisticated cameras offer ways to capture kids bouncing on a trampoline with a minimum of blurriness, but it's always going to be a problem.
If you don't want to switch to one of the more sophisticated cameras from a major brand, practice holding the camera steady during every shot and avoid shooting fast-moving subjects.
Jun 19, 2014 | Polaroid m737t Digital Camera
Headlight bulb
At night , Park on level ground approx. 6-8 feet away from a garage door, block wall... Somewhere you can see the level of your headlights. Under your hood , their should be screws, 1 controls vertical movement, & 1 controls horizontal movement. Some cars have a bubble level.... either way, turn each screw slowly to your desired placement. Then adjust the other too match. there are other ways. Wall, Plus Distance, Plus Tape on Wall, Intersect light to tape on wall
Apr 18, 2014 | 2004 Mini Cooper
Auto print head alignment wont work and I need to do a manual alignment. How do I do this for a MP970?
1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette. 2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension. 3. Press the Paper Feed Switch to select the paper source where you have loaded paper. 4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
5. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
6. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
7. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
Mar 01, 2011 | Office Equipment & Supplies
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
May 16, 2010 | Canon MP970 Photo All-In-One InkJet...
THE FIRST TWO LINES OF A PRINTED DOCUMENT ARE PRINTING DOUBLE.
If your printouts contain misaligned vertical lines, you may need to align the print head. Make sure the EPSON Stylus CX3200 is turned on and not printing, and the Error light is off. Load plain, letter-size paper in the sheet feeder. Press a Menu button until you see Head Alignment, then press the Color Copy button to print an alignment page. On the test page, select the pattern with the two vertical lines most precisely printed on top of each other. You may need to use a magnifying glass or loupe. maint.6.7.1.jpg Select one pattern each for rows 1, 2, and 3. (In this example, pattern 8 is the best in each row.) Press the + or - button to select the number of the best pattern for the first row, then press the Color Copy button. Repeat this step for the second and third rows. Note: If you select a pattern other than 8 in any row, that pattern becomes pattern #8 the next time you align the print head. When you’re finished, press the Stop button.
Feb 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
HP Designjet 4500 Scanner error 55-203,55-205. Appears at calibration at alignment of chambers
55-203
Problem:
No movement in camera position has been detected during vertical camera
alignment.
Possible Solutions:
Check all the cables connected to the Camera.
Run the scanner maintenance program.
May 18, 2009 | HP Designjet 4500 Pass-Through Scanner
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
White bands on color photo prints
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printing problem
  1. Open the Printers folder.
    • For Windows XP Select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    • For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon to open Properties.
  3. Click the 'Maintenance' tab and click the 'Print Head Alignment' icon.
  4. The message below is displayed. After confirming the two points below, click 'Print Head Alignment'.
  5. The following message is displayed. Click 'OK'. Print head cleaning starts. The power lamp flashes during cleaning operation. Do not perform other operations. After cleaning has finished, the first head alignment pattern will be printed.
  6. The following message is displayed. After printing has finished, click 'Yes'.
  7. Refer to the printed sheet, and select the pattern with the fewest visible vertical stripes in column A.
    <1> Example of highly visible vertical stripes in the pattern.
    <2> Example of the fewest visible vertical stripes in the pattern.
  8. Enter the selected pattern's number in the Column A box.
  9. Similarly, enter the selected numbers in the boxes for column B to F.
  10. After all numbers have been entered, click 'OK'.
Apr 09, 2008 | Office Equipment & Supplies
What do L.EMG and R.EMG mean and why do they prevent me from any activity with my camera?
Hello, The errors you are getting are "reel" errors. One or both of the tape reels are not turning during tape movement and the camera is shutting down to protect itself and your tape. In this model this problem is usually caused by the take up reel shaft being bent due to improper insertion of the cassette although this may not be the case. Please inspect both the takeup and supply tape reels and insure they are in correct alignment, if not, a gentle push to one side or the other will place them back in operating position. Good luck to you. Joe Weibel CustomElectronics.Org
Apr 22, 2007 | Samsung SCL901 Hi8mm Camcorder
VIDAR Systems Select P42 Logo
108 people viewed this question
Top VIDAR Systems Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a VIDAR Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
