Question about Spy Gear Spy Video Car VX-6
No signal the car did not work out of the box. the remote just says no signal. new batteries in both the car and the remote
Straight out of the box, camera is charged, battery is in the remote but the remote isnt working. Any ideas other than a new battery.
Do you have (or can you borrow) a battery tester ? Also, is the battery the right way round ? (basic, I know, but a possibility). Also, some cameras require telling to accept signals from the remote control (my Pentax does), so see if there is a menu setting for this. Remember to cancel it afterwards, or any other remote on the same frequency may trigger the shutter.
Dec 27, 2015 | Cameras
Sky box problems
Power off unit, unplug from wall, reconnect and clean sender unit on end of the remote, use smart phones camera to view the end of the remote when you push a button, you should see a change in color on the remotes eye, if not try new batteries again, retest, still no signal, try the other remote.
Nov 30, 2013 | Televison & Video
How to fix digital stream remote control
1) try to change a new batteries by the same type of batteries and full charged
2) clean the contacts battery with contacts cleaner
3) retight the springs contacts battery with pliers for better contacts
4) resolder the wires contacts battery
5) open the remote control and clean the keypads switchs with contacts cleaner for dirty, dust, oxide, bad contacts, open contact with VOM and fix it. Remember they receive signal from Syscon and emite infrared signal to the receiver
Otherwise you mus go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
2000 BMW my remote is not working. is that a battery type key? 2000 BMW 323I
yes it is you may need new battery on the remote take it to the auto part and the check you're batteries and remote signal.they have the tools to check remotes signal
Aug 30, 2010 | BMW 323 Cars & Trucks
The remote entry is transmitting a signal but it will not work.
There are ways to test it but how do you know that it is transmitting a signal? Batteries are new in the remote also right?
Jul 21, 2010 | 2000 Volkswagen Jetta TDI
Can't get keyboard to work. Mouse works fine. Replaced batteries in keyboard and tried to reconnect as I did with the mouse. No luck
You say that the battery is ok. Please be sure that the battery is new and placed in the right way.
After plugging the remote box to the PC you must sync the keyboard and the mouse.
The range may be problem. If you keep the keyboard more one or two meters away from the remote, the signal is lost. And if you put the cell phone next to the keyboard or mouse, it may interfere with them. It also may interfere with wireless phone, radio or television signals.
If it continues not to work, you can ask for the new one.
Hope it works.
Mar 24, 2010 | Logitech Cordless Desktop Optical...
Both of the remotes don't work. put in new
pull battery cables for a few minutes to reset ecm and remote signal receiver.
Oct 13, 2009 | Suzuki Aerio SX Cars & Trucks
TV DOES NOT RECEIVE THE SIGNAL FROM REMOTE CONTROL
radio shack used to sell the box dont know for sure if they still do
Feb 05, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
TIVO Remote Control Problem
A similar problem happend to me. Buying a new remote fixed it - for about three weeks.
Maybe your new one will work longer.
Mar 06, 2008 | Tivo DirectTV Remote Remote Control
Spy Gear Spy Video Car VX-6 Logo
170 people viewed this question
Top Spy Gear Video Cameras Experts
Are you a Spy Gear Video Camera Expert? Answer questions, earn points and help others
